I just spent several hours trying to figure out why, using a nRF52 dev kit w/ SDK13 + S132 on both central/client and peripheral/server side, sd_ble_gattc_read() was working like a charm while sd_ble_gattc_write() failed.
I added a debug trace to the BLE event manager top-level dispatch routine, i.e. softdevice_ble_evt_handler_set(ble_evt_dispatch) on the peripheral side to try to understand the problem with no success:
sd_ble_gattc_write()returned no error withBLE_GATT_OP_WRITE_CMDandBLE_GATTC_EVT_WRITE_CMD_TX_COMPLETEevent was successfully generated and/or,sd_ble_gattc_write()returned no error withBLE_GATT_OP_WRITE_REQandBLE_GATTC_EVT_WRITE_RSPevent was successfully generated with an zeroed length
while no BLE were even triggered on the peripheral side (where previous and next read requests were perfectly handled with the very same attribute and BLE connection).
I finally managed to locate my mistake: the write buffer on the central side was declared to be one byte longer than the actual attribute buffer maximum length on the peripheral side.
It seems that in this case, at least with no special configuration, no event is generated on the peripheral side to report the error, while the error on the central side is very hard to spot (written length == 0). I'm even more surprised not to received an event since the destination attribute was configured to request write permission.
From my understanding, it appears that the S132 SoftDevice discards a write request if the received buffer is longer than the declared attribute max length, but it does so silently.
Questions:
- how to get a warning/notification/trace/whatever on such an event ("write request to long") on the server so that it is possible to debug the issue without guessing :-)
- is it possible from a central role (client) to retrieve the maximum length of a peripheral attribute (server). I initially planned to use this feature for debug purpose, but as I failed to find an answer for this question, I skipped it. Maybe it is a limitation of the BLE protocol, but I failed to find an answer to this question
- is there a better way to detect this error on the client side (for now, the only way I found is to test the write length from the
BLE_GATTC_EVT_WRITE_RSPevent) - is there some documentation about this issue (or guidance to avoid it). The
NRF_ERROR_DATA_SIZEerror code forsd_ble_gattc_write()is not triggered, so maybe it is reserved for local out-of-range buffers. AFAICT, there is no piece of information about this potential trap
Thanks.
