nRF52840, SDK 14.0.0 and tickless idle FreeRTOS - some suggestions
This post is more about some suggestions for review rather than a question.
I've been looking at implementing a project using the nRF52840, SDK 14.0.0 and FreeRTOS in a low power application. The release note for SDK 14.0.0. indicates that FreeRTOS is not supported on the nRF52840, however I see no reason why FreeRTOS shouldn't work on this platform.
I ported the example ble_app_hrs_freertos app for ARM GCC to pca10056 and found that current consumption was very high even with tickless idle enabled. Upon profiling the idle code, I found that sd_app_event_wait() was being called and then exiting immediately on every iteration of the idle loop.
There were what seemed to be a number of improvements that could be made. Please see the attached port_cmsis_systick.c files for my suggested changes.
They include:
  • Don't turn off app interrupts when going into idle. Instead only turn off RTC timing interrupts. This should improve interrupt latency while sleeping since interrupt handlers will run directly after return from WFE events. This also allows interrupt handlers to make FreeRTOS API calls which could potentially set tasks to running.
  • Stay as long as possible in the inner tickless idle loop if there is no reason to exit. That is, the only reason to exit idle is if a task has been scheduled to run, or the maximum time to wait has elapsed.
  • Don't rely solely on RTC capture compare interrupt to wake from WFE. Instead, use a counter comparison check to determine if wait time has elapsed.
  • Clear pending CPU event using SEV/WFE before testing for idle exit and going to sleep. This prevents any event prior to going to idle from waking the CPU immediately on a call to sd_app_event_wait().
There are likely some improvements to make to this code, however I have found that these changes result in a significant reduction in consumed power.
The attached port_cmsis_systick_with_profiling.c contains a set of counters which are ticked at various points of the idle loop to try and gain an understanding of how often events occur. eg We can determine how often the code requests idle, how many times we wake CPU from idle but the conditions for FreeRTOS are not met to exit idle (eg as a result of a BLE interrupt).
I'd be interested in feedback on this approach and to know if there are any holes in my reasoning with the proposed changes.
I've attached the ble_app_hrs_freertos app ported to pca10056. This also includes an FPU_IRQHandler to address issues with CPU not sleeping with FPU interrupt pending.
ble_app_hrs_freertos_pca10056.tgz
UPDATED 16th Oct 2018:
See the updated port_cmsis_systick.c which includes important changes including the following:
  • Fixes a bug which could result in infinite sleep in idle.  Ensure that pending RTC wake interrupt is cleared before entry to sleep.
  • Ensures pending FPU interrupts are cleared before entry to sleep.
  • Support GPIO profiling of time spent asleep.  Use critical section around WFE instruction when profiling to ensure that GPIO pins are set to show CPU asleep/awake state prior to interrupt handlers running.
 * FreeRTOS Kernel V10.0.0
 * Copyright (C) 2017 Amazon.com, Inc. or its affiliates.  All Rights Reserved.
 * Permission is hereby granted, free of charge, to any person obtaining a copy of
 * this software and associated documentation files (the "Software"), to deal in
 * the Software without restriction, including without limitation the rights to
 * use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of
 * the Software, and to permit persons to whom the Software is furnished to do so,
 * subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in all
 * copies or substantial portions of the Software. If you wish to use our Amazon
 * FreeRTOS name, please do so in a fair use way that does not cause confusion.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS
 * FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
 * COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER
 * IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
 * CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
 * http://www.FreeRTOS.org
 * http://aws.amazon.com/freertos
 * 1 tab == 4 spaces!
/* Scheduler includes. */
#include "FreeRTOS.h"
#include "task.h"
#include "app_util.h"
#include "nrf_log.h"
#ifdef SOFTDEVICE_PRESENT
#include "nrf_soc.h"
#include "nrf_sdh.h"
#include "app_error.h"
#define PROFILE_TICKLESS_IDLE    0
#if PROFILE_TICKLESS_IDLE == 1
#define ARRAY_SIZE(arr) (sizeof(arr) / sizeof((arr)[0]))
struct {
    /* Total number of times the idle wait loop is entered. */
    uint32_t n_idle_loops;
    /* The number of time the CPU is woken from sd_app_evt_wait() due to an event
     * where the event hasn't cause a reschedule or the tickless idle time has elapsed.
    uint32_t n_cpu_wake_no_rtc_or_sched;
    /* Number of time an exit from idle occurs during a scheduling event.
     * Also extract number of time this occurs based on how many times the
     * CPU wakes up (loop variables).
    uint32_t n_sched_idle_wakeup;
    uint32_t n_sched_idle_wakeup_loop[10];
    /* Number of time an exit from idle occurs during RTC time elapsed.
    uint32_t n_rtc_idle_wakeup;
    uint32_t n_rtc_idle_wakeup_loop[10];
    /* Number of times sd_app_evt_wait is called. */
    uint32_t n_sd_app_evt_wait;
} profile_tickless_g;
 * Implementation of functions defined in portable.h for the ARM CM4F port.
 * CMSIS compatible layer to menage SysTick ticking source.
#if configTICK_SOURCE == FREERTOS_USE_SYSTICK
#ifndef configSYSTICK_CLOCK_HZ
    #define configSYSTICK_CLOCK_HZ configCPU_CLOCK_HZ
    /* Ensure the SysTick is clocked at the same frequency as the core. */
    #define portNVIC_SYSTICK_CLK_BIT    ( SysTick_CTRL_CLKSOURCE_Msk )
#else
    /* The way the SysTick is clocked is not modified in case it is not the same
    as the core. */
    #define portNVIC_SYSTICK_CLK_BIT    ( 0 )
#if configUSE_TICKLESS_IDLE == 1
    #error SysTick port for RF52 does not support tickless idle. Use RTC mode instead.
#endif /* configUSE_TICKLESS_IDLE */
void xPortSysTickHandler( void )
    /* The SysTick runs at the lowest interrupt priority, so when this interrupt
    executes all interrupts must be unmasked.  There is therefore no need to
    save and then restore the interrupt mask value as its value is already
    known. */
    ( void ) portSET_INTERRUPT_MASK_FROM_ISR();
        /* Increment the RTOS tick. */
        if ( xTaskIncrementTick() != pdFALSE )
            /* A context switch is required.  Context switching is performed in
            the PendSV interrupt.  Pend the PendSV interrupt. */
            SCB->ICSR = SCB_ICSR_PENDSVSET_Msk;
    portCLEAR_INTERRUPT_MASK_FROM_ISR( 0 );
 * Setup the systick timer to generate the tick interrupts at the required
 * frequency.
void vPortSetupTimerInterrupt( void )
    /* Set interrupt priority */
    NVIC_SetPriority(SysTick_IRQn, configKERNEL_INTERRUPT_PRIORITY);
    /* Configure SysTick to interrupt at the requested rate. */
    SysTick->LOAD = ROUNDED_DIV(configSYSTICK_CLOCK_HZ, configTICK_RATE_HZ) - 1UL;
    SysTick->CTRL = ( portNVIC_SYSTICK_CLK_BIT | SysTick_CTRL_TICKINT_Msk | SysTick_CTRL_ENABLE_Msk );
#elif configTICK_SOURCE == FREERTOS_USE_RTC
#if configUSE_16_BIT_TICKS == 1
#error This port does not support 16 bit ticks.
#include "nrf_rtc.h"
#include "nrf_drv_clock.h"
    nrf_rtc_event_clear(portNRF_RTC_REG, NRF_RTC_EVENT_COMPARE_0);
    BaseType_t switch_req = pdFALSE;
    uint32_t isrstate = portSET_INTERRUPT_MASK_FROM_ISR();
    uint32_t systick_counter = nrf_rtc_counter_get(portNRF_RTC_REG);
    nrf_rtc_event_clear(portNRF_RTC_REG, NRF_RTC_EVENT_TICK);
    if (configUSE_DISABLE_TICK_AUTO_CORRECTION_DEBUG == 0)
        /* check FreeRTOSConfig.h file for more details on configUSE_DISABLE_TICK_AUTO_CORRECTION_DEBUG */
        TickType_t diff;
        diff = (systick_counter - xTaskGetTickCount()) & portNRF_RTC_MAXTICKS;
        /* At most 1 step if scheduler is suspended - the xTaskIncrementTick
         * would return the tick state from the moment when suspend function was called. */
        if ((diff > 1) && (xTaskGetSchedulerState() != taskSCHEDULER_RUNNING))
            diff = 1;
        while ((diff--) > 0)
            switch_req |= xTaskIncrementTick();
        switch_req = xTaskIncrementTick();
    /* Increment the RTOS tick as usual which checks if there is a need for rescheduling */
    if ( switch_req != pdFALSE )
    portCLEAR_INTERRUPT_MASK_FROM_ISR( isrstate );
 * Setup the RTC time to generate the tick interrupts at the required
 * frequency.
    /* Request LF clock */
    nrf_rtc_prescaler_set(portNRF_RTC_REG, portNRF_RTC_PRESCALER);
    nrf_rtc_int_enable   (portNRF_RTC_REG, RTC_INTENSET_TICK_Msk);
    nrf_rtc_task_trigger (portNRF_RTC_REG, NRF_RTC_TASK_CLEAR);
    nrf_rtc_task_trigger (portNRF_RTC_REG, NRF_RTC_TASK_START);
    nrf_rtc_event_enable(portNRF_RTC_REG, RTC_EVTEN_OVRFLW_Msk);
    NVIC_SetPriority(portNRF_RTC_IRQn, configKERNEL_INTERRUPT_PRIORITY);
    NVIC_EnableIRQ(portNRF_RTC_IRQn);
static inline void waitCpuCoreEvent()
#ifdef TRACE_LOW_POWER
    /* When tracing entry/exit to WFE MCU sleep mode use an additional critical section.
     * Interrupts are normally enabled when MCU is sleeping so interrupt handlers run immediately
     * on wake from WFE.  Without an additional critical section the interrupt handler that woke
     * MCU would have already run before the trace pin is changed resulting in an inaccurate
     * representation of the time the MCU spends asleep.
    CRITICAL_REGION_ENTER();
    traceLOW_POWER_WFE_BEGIN();
    if (nrf_sdh_is_enabled()) {
        uint32_t err_code = sd_app_evt_wait();
    else {
        __WFE();
    traceLOW_POWER_WFE_END();
    CRITICAL_REGION_EXIT();
#else
    __WFE();
#if __FPU_PRESENT
    #define PWR_MGMT_FPU_SLEEP_PREPARE()     pwr_mgmt_fpu_sleep_prepare()
     __STATIC_INLINE void pwr_mgmt_fpu_sleep_prepare(void)
        uint32_t fpscr;
        fpscr = __get_FPSCR();
         * Clear FPU exceptions.
         * Without this step, the FPU interrupt is marked as pending,
         * preventing system from sleeping. Exceptions cleared:
         * - IOC - Invalid Operation cumulative exception bit.
         * - DZC - Division by Zero cumulative exception bit.
         * - OFC - Overflow cumulative exception bit.
         * - UFC - Underflow cumulative exception bit.
         * - IXC - Inexact cumulative exception bit.
         * - IDC - Input Denormal cumulative exception bit.
        __set_FPSCR(fpscr & ~0x9Fu);
        __DMB();
        NVIC_ClearPendingIRQ(FPU_IRQn);
#else
void vPortSuppressTicksAndSleep( TickType_t xExpectedIdleTime )
    /* Upon entry the scheduler is suspended, RTC is still generating tick interrupts. */
    /* Choose a maximum idle time much less than available maximum to allow for safe RTC counter
     * bounds checking after wakeup from sleep.
    TickType_t maxIdleTime = portNRF_RTC_MAXTICKS / 2 - configEXPECTED_IDLE_TIME_BEFORE_SLEEP;
    if ( xExpectedIdleTime > maxIdleTime )
        xExpectedIdleTime = maxIdleTime;
    /* Block RTC interrupts only.  All other interrupt remain active so that they
     * can execute directly after WFE and possibly schedule RTOS tasks.
    do{
        uint32_t err_code = sd_nvic_DisableIRQ(portNRF_RTC_IRQn);
    }while (0);
#else
    NVIC_DisableIRQ(portNRF_RTC_IRQn);
     * Implementation note:
     * To help debugging the option configUSE_TICKLESS_IDLE_SIMPLE_DEBUG was presented.
     * This option would make sure that even if program execution was stopped inside
     * this function no more than expected number of ticks would be skipped.
     * Normally RTC works all the time even if firmware execution was stopped
     * and that may lead to skipping too much of ticks.
    TickType_t enterTime;
    enterTime = nrf_rtc_counter_get(portNRF_RTC_REG);
    if ( eTaskConfirmSleepModeStatus() != eAbortSleep )
        TickType_t xModifiableIdleTime;
        TickType_t wakeupTime = (enterTime + xExpectedIdleTime) & portNRF_RTC_MAXTICKS;
        /* Stop tick events */
        nrf_rtc_int_disable(portNRF_RTC_REG, NRF_RTC_INT_TICK_MASK);
        /* Configure CTC interrupt */
        nrf_rtc_cc_set(portNRF_RTC_REG, 0, wakeupTime);
        nrf_rtc_int_enable(portNRF_RTC_REG, NRF_RTC_INT_COMPARE0_MASK);
        /* Ensure NVIC->ISPR[RTC] (Pending interrupt) for RTC is clear before entering wait loop.
         * Exit from WFE relies on generation of an event from NVIC->ISPR[RTC] transitioning from
         * 0->1 as a result of tickless timeout coming from RTC COMPARE0 interrupt event.
            uint32_t err_code = sd_nvic_ClearPendingIRQ(portNRF_RTC_IRQn);
#else
        NVIC_ClearPendingIRQ(portNRF_RTC_IRQn);
        __DSB();
        /* Sleep until something happens.  configPRE_SLEEP_PROCESSING() can
         * set its parameter to 0 to indicate that its implementation contains
         * its own wait for interrupt or wait for event instruction, and so wfi
         * should not be executed again.  However, the original expected idle
         * time variable must remain unmodified, so a copy is taken. */
        xModifiableIdleTime = xExpectedIdleTime;
        configPRE_SLEEP_PROCESSING( xModifiableIdleTime );
        if ( xModifiableIdleTime > 0 )
                uint32_t loopCounter = 0;
                while (1) {
                    uint32_t currentTime;
                    ++profile_tickless_g.n_idle_loops;
                    /* Clear prior pending CPU events to ensure that sd_app_evt_wait() will wait
                     * on useful wakeup event rather than wakeup immediately due to events which
                     * have occurred since we last went to sleep.
                     * The only reasons to exit from idle are:
                     *  - There is a task scheduled to run
                     *  - The expected idle time has elapsed
                    __SEV();
                    __WFE();
                    if (eTaskConfirmSleepModeStatus() == eAbortSleep) {
                        if (loopCounter < ARRAY_SIZE(profile_tickless_g.n_sched_idle_wakeup_loop)) {
                            ++profile_tickless_g.n_sched_idle_wakeup_loop[loopCounter];
                        ++profile_tickless_g.n_sched_idle_wakeup;
                    currentTime = nrf_rtc_counter_get(portNRF_RTC_REG);
                    /* Is current RTC count outside of the window that CPU is expected to sleep?
                     * Account for case where RTC wakeup time may overflow.
                    if (wakeupTime < enterTime) {
                        if (currentTime >= wakeupTime && currentTime < enterTime) {
                            if (loopCounter < ARRAY_SIZE(profile_tickless_g.n_rtc_idle_wakeup_loop)) {
                                ++profile_tickless_g.n_rtc_idle_wakeup_loop[loopCounter];
                            ++profile_tickless_g.n_rtc_idle_wakeup;
                    else {
                        if (currentTime < enterTime || currentTime >= wakeupTime) {
                    ++profile_tickless_g.n_sd_app_evt_wait;
                    if (loopCounter != 0) {
                        ++profile_tickless_g.n_cpu_wake_no_rtc_or_sched;
                    PWR_MGMT_FPU_SLEEP_PREPARE();
                    waitCpuCoreEvent();
                    ++loopCounter;
        configPOST_SLEEP_PROCESSING( xExpectedIdleTime );
        nrf_rtc_int_disable(portNRF_RTC_REG, NRF_RTC_INT_COMPARE0_MASK);
        /* Correct the system ticks */
            TickType_t diff;
            TickType_t exitTime;
            nrf_rtc_int_enable (portNRF_RTC_REG, NRF_RTC_INT_TICK_MASK);
            exitTime = nrf_rtc_counter_get(portNRF_RTC_REG);
            diff =  (exitTime - enterTime) & portNRF_RTC_MAXTICKS;
            /* It is important that we clear pending here so that our corrections are latest and in sync with tick_interrupt handler */
#else
            if ((configUSE_TICKLESS_IDLE_SIMPLE_DEBUG) && (diff > xExpectedIdleTime))
                diff = xExpectedIdleTime;
            if (diff > 0)
                vTaskStepTick(diff);
    uint32_t err_code = sd_nvic_EnableIRQ(portNRF_RTC_IRQn);
#else
#endif // configUSE_TICKLESS_IDLE
#else // configTICK_SOURCE
    #error  Unsupported configTICK_SOURCE value
#endif // configTICK_SOURCE == FREERTOS_USE_SYSTICK
  • @gkovelman_tap Thanks for information about your setup, good to have another data point. A colleague independently ported ble_app_hrs_freertos to PCA10056 using IAR compiler and he obtained the same high > 6mA consumption measurements so I assumed that it was an issue with the source, not our setup. What board are you using and what consumption do you achieve with tickless? Which SoftDevice are you using? For profiling I added a counter after sd_app_event_wait() in port_cmsis_systick.c (line 284) and found that this line was being hit a very large number of times.
  • Using a custom board with NRF52832, S132 v5.0.0, SDK 14.0.0, IAR 7.80.4. Honestly, the only issue is the FPU errata. I can't tell the NRF52's exact consumption, but it is less than 100uA. Make sure that you don't measure the consumption when debugging and you don't have any logging such as RTT logging. What are the numbers that you're seeing?
  • Thanks for sharing this; I've been trying to do similar things but have not made as much progress. I'm trying to download your ble_app_hrs_freertos_pca10056.tgz, but when I click on the link, the web site gives me port_cmsis_systick_with_profiling.c instead, consistently. Web site malfunction? Could you put the tgz online somewhere else?
  • @Eric I've re-uploaded the tgz to the post (I likely made an error during upload), please retry
  • @gkovelman_tap I'm just using the ble_app_hrs{_freertos} example, I've been more interested in comparative measurements between FreeRTOS/non-FreeRTOS examples. For pca10056, that difference is over 6mA. Nordic hrs example without FreeRTOS 650uA, hrs example with FreeRTOS 6.7mA, with my FreeRTOS changes 670uA. As you indicate, there's additional things I can do to minimise the power. I suspect the FreeRTOS tickless behaviour on pca10056 is related to use of S140, it's possibly got a different timing profile for its BLE interrupts and this is usually masked in normal apps by the tight while(1) { sd_app_event_wait(); process() } loops in main().
