nRF2840: IPv6 over BLE to IPv4 internet via NAT64
I am really new to the field, I apologise, if things I am saying do not make sense, explanations and corrections appreciated :) I am trying to reach IPv4 internet from my PCA10056 nRF52840 node which is running IoT icmp example with adapted headers from PCA10040 nRF52832 so the buttons and LED's work. It is connected via BLE to my border router Raspberry Pi 3B, running Debian Stretch.
I can ping the nodes local "fe80" and "2001" addresses from the router. The node can ping local bt0 IPv6 address, tcp server/client setup works as well. As my ISP does not provide IPv6, I am using Tayga to communicate to IPv4 internet via IPv6. I have tried pinging Google's IPv4 address using NAT64 prefix from my Raspberry Pi and it works, although when I am trying to do the same with from the node, I get an error in tcpdump destination unreachable, beyond scope <prefix::808:808>.
I was thinking, that the bt0 interface cannot access anything beyond bt0, hence the ethernet interface is unreachable. My question is, would a bridge between the bt0 and ethernet interface help to solve my problem? If so, I would appreciate any tutorials or explanations how to successfully do that. Or would a tunnel broker such as hurricane electric be a better idea to just bypass all the IPv4 translation?
tayga.conf:
tun-device nat64
ipv4-addr 192.168.255.1
prefix 2001:db8:1:ffff::/96
dynamic-pool 192.168.255.0/24
data-dir /var/db/tayga
My ifconfig:
bt0: flags=4177<UP,POINTOPOINT,RUNNING,MULTICAST>  mtu 1280
        inet6 2001:db8::1  prefixlen 64  scopeid 0x0<global>
        inet6 fe80::4343:a1ff:fe12:1fac  prefixlen 64  scopeid 0x20<link>
        unspec 41-43-A1-FF-FE-12-1F-AC-00-00-00-00-00-00-00-00  txqueuelen 1  (UNSPEC)
        RX packets 12  bytes 496 (496.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 37  bytes 2187 (2.1 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
enxb827eb0ab32d: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.5.129  netmask 255.255.255.0  broadcast 192.168.5.255
        inet6 2001:db8:1::1  prefixlen 64  scopeid 0x0<global>
        inet6 fe80::ba27:ebff:fe0a:b32d  prefixlen 64  scopeid 0x20<link>
        ether b8:27:eb:0a:b3:2d  txqueuelen 1000  (Ethernet)
        RX packets 4281  bytes 4697929 (4.4 MiB)
        RX errors 0  dropped 4  overruns 0  frame 0
        TX packets 2934  bytes 341453 (333.4 KiB)
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1  (Local Loopback)
        RX packets 270  bytes 19420 (18.9 KiB)
        TX packets 270  bytes 19420 (18.9 KiB)
nat64: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST>  mtu 1500
        inet 192.168.5.129  netmask 255.255.255.255  destination 192.168.5.129
        inet6 fe80::e95a:684b:91f5:e2ca  prefixlen 64  scopeid 0x20<link>
        inet6 2001:db8:1::1  prefixlen 128  scopeid 0x0<global>
        unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00  txqueuelen 500  (UNSPEC)
        RX packets 6  bytes 564 (564.0 B)
        TX packets 20  bytes 1544 (1.5 KiB)
route -n -A inet6:
Destination                    Next Hop                   Flag Met Ref Use If
2001:db8::/64                  ::                         U    256 0     0 bt0
2001:db8:1::1/128              ::                         U    256 0     0 nat64
2001:db8:1::/64                ::                         U    256 0     0 wlan0
2001:db8:1::/64                ::                         U    256 0     0 enxb827eb0ab32d
2001:db8:1:ffff::/96           ::                         U    1024 1    11 nat64
fe80::/64                      ::                         U    256 0     0 wlan0
fe80::/64                      ::                         U    256 0     0 enxb827eb0ab32d
fe80::/64                      ::                         U    256 0     0 nat64
fe80::/64                      ::                         U    256 1    23 bt0
::/0                           ::                         !n   -1  1   212 lo
::1/128                        ::                         Un   0   5     8 lo
2001:db8::/128                 ::                         Un   0   1     0 lo
2001:db8::1/128                ::                         Un   0   1     0 lo
2001:db8:1::/128               ::                         Un   0   1     0 lo
2001:db8:1::1/128              ::                         Un   0   3     6 lo
2001:db8:1::1/128              ::                         Un   0   1     0 lo
2001:db8:1::1/128              ::                         Un   0   2     3 lo
fe80::/128                     ::                         Un   0   1     0 lo
fe80::4343:a1ff:fe12:1fac/128  ::                         Un   0   2     5 lo
fe80::ba27:ebff:fe0a:b32d/128  ::                         Un   0   1     0 lo
fe80::ba27:ebff:fe5f:e678/128  ::                         Un   0   1     0 lo
fe80::e95a:684b:91f5:e2ca/128  ::                         Un   0   1     0 lo
ff00::/8                       ::                         U    256 2    12 wlan0
ff00::/8                       ::                         U    256 3   233 enxb827eb0ab32d
ff00::/8                       ::                         U    256 1     3 nat64
ff00::/8                       ::                         U    256 3    13 bt0
I appreciate the help,
Karolis
  • Hi Karolis,
    I would say that using prefixes like 2003: and 2004: would couse you more trouble in the long run. If it does not work with the 64:ff9b::/96 prefix for tayga it clearly means that there are more issues to solve not that the prefix is incorrect. I would strongly encourage you to stick to 64:ff9b::/96 for NAT64.
    Could you look at the tcpdump on the nat64 interface? Do you see packets coming from the bt0?
    Kind regards, Piotr Szkotak
  • Hi, thanks for trying to help. On tcpdump nat64 interface there is nothing received with any of the prefixes. Using 64:ff9b::/96 I cannot even ping myself, as earlier, I am getting a "No route" error. I am not sure what should I set my tayga ipv6 address to, since I can't use 64:ff9b:: prefix for it. I tried 2001:db8:7777::1, but even after adding it to nat64 interface it still does not work.
    I have tried with a TI device, and it works with 2004 prefix, hence this shouldn't be the origin of the problem. As I said before, when I add a global ipv6 address to the bt0 interface it should use the global prefix, not the local one. This happens with the TI device, it uses the global address assigned and can communicate even over the internet without problems.
    Kind Regards, Karolis
  • If you receive "no route" error I expect there is missing entry in the routing table. I do not have the proper hardware on my desk at this moment, and I am not sure what exactly did you do. As the starting point I would set tayga.conf to: tun-device nat64 ipv4-addr 192.168.64.1 prefix 64:ff9b::/96 data-dir /var/db/tayga
    Then I would clean current tayga database: rm -r /var/db/tayga mkdir -p /var/db/tayga/ touch /var/db/tayga/dynamic.map ip link del dev nat64
    Then I would set it back again. tayga --mktun ip link set nat64 up ip addr add 64:ff9b::1 dev nat64 ip addr add 64:ff9b::/64 dev nat64 ip route add 192.168.64.0/24 dev nat64 ip route add 64:ff9b::/64 dev nat64
    I would also set bt0 addr and add route to it. ip addr add fdff:cafe:cafe:cafe::/64 dev bt0 ip route add fdff:cafe:cafe:cafe::/64 dev bt0
  • The suggested tayga configuration does not work, if you are using 64:ff9b::/96 prefix, you need to set ipv6 address for tayga.
  • Indeed, you may need to add another address which is outside of the nat64 64bit long prefix scope.
    In case of futher issues I would first check the routing table and then traffic on the bt0, nat64 and the ethernet interface with the tcpdump.
