fds in sdk14
I'm trying to migrate my old app based on buttonless app sdk13 to buttonless app sdk14. I solved issuie according to migrate guide remove chunk things and etc. My app works well until I add fds_init function in my main.c file.
Here's my fds_test_init function
ret_code_t fds_test_init (void)
		ret_code_t ret = fds_register(fds_evt_handler);
		if (ret != FDS_SUCCESS)
					return ret;
		ret = fds_init();
				return ret;
		return NRF_SUCCESS;
After I comment calling of that function in my main.c the app starts work. After comment again not working. I see nothing in RTT terminal
The same code works well with sdk13
  • I've tried to get ret_code using function SEGGER_RTT_printf(0, "%d", ret_code); but I get nothing in terminal if use fds_init function even if I to write any message before calling fds_init. Also I've tried to get err_code via debugging (keil), I set breakpoint next to ret_code_t ret = fds_register(fds_evt_handler); but in watch window most of the time err_code's value . screen is there any guide how to get ret_code?
  • I forgat to change optimization level of debugging to level 0. So now I can see that ret either returned by fds_register or fds_init functions is 0.
  • If it's returning 0 that means success, so this is not where your issue is. Be sure to fully erase the chip when re-programming since old FDS data is maintained and can cause issues if you changing your FDS implementation.
  • Yes. I do all the time by that way (eraseall, program softdevice, program app). There were not any problems with sdk13, but now... There's main function
        bool erase_bonds;
    		uint32_t err_code;
        // Initialize.
        log_init();
    		SEGGER_RTT_printf(0, "start app\n\r");
    		m_clock_timer_init();
    		pwm_init_corr();
    		pwm_init_rgb();
    		HX711_init();
    		err_code = fds_test_init();
    	//fds_init_values();
    	//fds_get_init_data();
    		//test_expired();
    		//fds_clear();
    	//	rgb_set(50, 50, 50, 3, 1500);
        timers_init();
        power_management_init();
        ble_stack_init();
        peer_manager_init();
        gap_params_init();
        gatt_init();
        advertising_init();
        services_init();
        conn_params_init();
        //NRF_LOG_INFO("Start scale driver app\n");
        // Start execution.
        application_timers_start();
        advertising_start(erase_bonds);
        // Enter main loop.
        for (;;)
                nrf_pwr_mgmt_run();
    If I comment these raws:
    //err_code = fds_test_init();
        //		APP_ERROR_CHECK(err_code);
    app starts work
  • Check your fds_evt_handler for error codes for "FDS_EVT_INIT".
