NRF52840 UART1 not working in SDK 14
I'm trying to run two UARTs out of my NRF52840. Do you have an example in which both SoftDevice UARTs are used? The Nordic Infocenter SDK 14.0.0 documentation lists one of the advantages of the new serial port library as multi-instance capability, but there is no example demonstrating such usage.
I started in SDK 12 and wrote my own alternative to app_uart that would allow multiple UART instances. After enabling UART0 and UART1 in the SDK config, I was unable to get both working at the same time. When I initialized a single UART using the board's default TX/RX pins (6 & 8 for pca10056) and NRF_UARTE0 (0x0002000) I was able to see all my serial data come through fine. However, switching to use NRF_UARTE1 (0x40028000) causes the app to crash and restart on attempting to read or write data, despite my using the same pins and configuration parameters as with UART0.
I've seen other questions regarding similar issues, and the general response was that the SDK 14 serial class would resolve this issue. However, I have since downloaded SDK 14 and am seeing the same behavior. I can initialize one UART port with nrf_serial_init, provided the serial port instance uses NRF_UARTE0/NRF_UART0, but again the same parameters do not work with NRF_UARTE1.
  • Hi Vernon,
    I have the same problem, we are developing an application on the nRF52840, we are using Keil as compiler. I have used the example project serial_uartes with SDK15.1. I begin by recieving data from the first uart and it works fine. When i beginning to receive data from second uart both the uart stop to work.
    In the example I modified only the receive and trasmision pins and the baude rate of one of the two uart (the first uart is 9600, the second 115200). What do you think? ( I attached sdk_config.h file )
    7167.sdk_config.h
     * Copyright (c) 2018, Nordic Semiconductor ASA
     * All rights reserved.
    #include <stdint.h>
    #include <stdbool.h>
    #include <stddef.h>
    #include "nrf.h"
    #include "nrf_drv_clock.h"
    #include "nrf_gpio.h"
    #include "nrf_delay.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_drv_power.h"
    #include "nrf_serial.h"
    #include "app_timer.h"
    #include "app_error.h"
    #include "app_util.h"
    #include "boards.h"
    /** @file
     * @defgroup nrf_serial_uartes_example main.c
     * @ingroup nrf_serial_uartes_example
     * @brief Example of @ref nrf_serial usage. Loopback example using two UARTE peripherals.
     *        Please short Arduino SCL and SDA GPIOs to start transmission.
    #define OP_QUEUES_SIZE          3
    #define APP_TIMER_PRESCALER     NRF_SERIAL_APP_TIMER_PRESCALER
    static void sleep_handler(void)
        __WFE();
        __SEV();
        __WFE();
    NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uarte0_drv_config,
                          RX_PIN_NUMBER, TX_PIN_NUMBER,
                          RTS_PIN_NUMBER, CTS_PIN_NUMBER,
                          NRF_UART_HWFC_DISABLED, NRF_UART_PARITY_EXCLUDED,
                          NRF_UART_BAUDRATE_9600,
                          UART_DEFAULT_CONFIG_IRQ_PRIORITY);
    NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uarte1_drv_config,
                          3, 4,
                          NRF_UART_BAUDRATE_115200,
    #define SERIAL_FIFO_TX_SIZE 32
    #define SERIAL_FIFO_RX_SIZE 32
    NRF_SERIAL_QUEUES_DEF(serial0_queues, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE);
    NRF_SERIAL_QUEUES_DEF(serial1_queues, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE);
    #define SERIAL_BUFF_TX_SIZE 1
    #define SERIAL_BUFF_RX_SIZE 1
    NRF_SERIAL_BUFFERS_DEF(serial0_buffs, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE);
    NRF_SERIAL_BUFFERS_DEF(serial1_buffs, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE);
    NRF_SERIAL_CONFIG_DEF(serial0_config, NRF_SERIAL_MODE_DMA,
                          &serial0_queues, &serial0_buffs, NULL, sleep_handler);
    NRF_SERIAL_CONFIG_DEF(serial1_config, NRF_SERIAL_MODE_DMA,
                          &serial1_queues, &serial1_buffs, NULL, sleep_handler);
    NRF_SERIAL_UART_DEF(serial0_uarte, 0);
    NRF_SERIAL_UART_DEF(serial1_uarte, 1);
        ret_code_t ret;
        ret = nrf_drv_clock_init();
        APP_ERROR_CHECK(ret);
        ret = nrf_drv_power_init(NULL);
        ret = app_timer_init();
        // Initialize LEDs and buttons.
        bsp_board_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS);
        ret = nrf_serial_init(&serial0_uarte, &m_uarte0_drv_config, &serial0_config);
        ret = nrf_serial_init(&serial1_uarte, &m_uarte1_drv_config, &serial1_config);
    		char	tmp_buff_send [ 10 ] = { 0x50 , 0x00 , 0x05 , 0x23 , 0x04 , 0x64 , 0x03 , 0x01 , 0x00 , 0x14 } ;
    		// Attivo la funzione autolistcard
    		( void ) nrf_serial_write ( &serial1_uarte , &tmp_buff_send , 10 , NULL , 100 ) ;
        static char tx_message[] = "Hello nrf_serial!\n\r";
        ret = nrf_serial_write(&serial0_uarte,
                               tx_message,
                               strlen(tx_message),
                               NULL,
                               NRF_SERIAL_MAX_TIMEOUT);
        (void)nrf_serial_flush(&serial1_uarte, 0);
        while (true)
            char c;
            ret = nrf_serial_read(&serial0_uarte, &c, sizeof(c), NULL, 1);
            if (ret != NRF_SUCCESS)
                continue;
            (void)nrf_serial_write(&serial0_uarte, &c, sizeof(c), NULL, 0);
            (void)nrf_serial_flush(&serial0_uarte, 0);
            ret = nrf_serial_read(&serial1_uarte, &c, sizeof(c), NULL, 1);
                continue;
  • Please post your issue in a new question. Also include any error codes you are getting, or information about where the application get stuck.
  • Hi Gianmarco,
    yes, it happened to my project the same as you, I didn't know how it occurred also, and when I stop debugging, it went to the app_error_fault_handler, the error ID is 0x01(see the following shot), hope someone could solve this issue as soon as possible.
  • I am using SDK15 and I replaced the programs according to new files. But I got some new ERRORS.
  • This is caused by missing source files (integration\nrfx\legacy\nrf_drv_clock.c - components\libraries\balloc\nrf_balloc.c) and/or modules not being enabled in sdk_config.h file:
    // <e> NRF_CLOCK_ENABLED - nrf_drv_clock - CLOCK peripheral driver - legacy layer
    #ifndef NRF_CLOCK_ENABLED
    #define NRF_CLOCK_ENABLED 1
    // <e> NRF_BALLOC_ENABLED - nrf_balloc - Block allocator module
    #ifndef NRF_BALLOC_ENABLED
    #define NRF_BALLOC_ENABLED 1
