Device not connecting after DFU OTA
I am running the BLE DFU example. I am able to perform the DFU OTA implementation successfully. The problem I am facing is that, once the application has been updated successfully, the device gets disconnected and starts advertising with new name. But when I am trying to connect to it, its disconnecting again and again.
I am using the hrm zip file for updating. The device after updating advertises as Nordic_HRM.But I am not able to connect to it.
  • @Bjorn I tried as you suggested. I compiled the HRM example and created a zip file using the generated hex file. But I am not ble to upload the zip file.
    I am facing the same problem which I mentioned in the previous comment.While uploading , it goes till "Starting DFU" and then gets disconnected or hangs with the status showing "Disconnecting".
  • Which nrfutil version did you use to generate the .zip? Could you post the nrfutil command that you used to generate the .zip ?
  • I am using nrfutil v2.3.0.
    the command I used i following
    nrfutil pkg generate --hw-version 52 --sd-req 0x81 --application-version 1 --application HRM.hex --key-file hrmkey.pem hrm_dfu.zip
  • If you're using SDK v11.0.0 then you need to use nrfutil v0.5.2 or older, which can be downloaded from here. All newer versions are for the new Secure DFU only.
  • I tried with the nrfutil v 0.5.2. I am still facing the same problem.
    Meanwhile I have one more doubt.When I am flashing the softdevice and bootloader from 10040 board, I am having no problem, whereas when I am doing the same with the 10036 board, after flashing the softdevice, I am unable to flash bootloader code.It gives the following error, the hex file has data in softdevice region.
