Can somebody provide me the the tutorial of how to interface nrf51822 with MPU6050 ?
Hi there, I am begineer for nrf51822 and I want to interface MPU6050 WITH nrf51822 so can somebody provide me the tutorial with full detail.i want to read just raw values of mpu6050. How to use Neil I'd? How to write a program for nrf51822?
Great help appreciated!!!
Regards Abhijeet
  • hi mango, my code is working but i am stuck in this situation.i am trying to get mpu output on segger rtt viwer but the error is "could not initialize connection" i couldn't get the output readings as per expected.what are the settings that i need to make to get output on rtt viwer.
  • Hello, Abhijeet kapse. You can check the RTT settings from my question.
    However, I haven't faced the could not initialize connection error.
    I think the coding problem for using the MPU series, which was your original problem, is solved to a certain degree.
    Can you create a new question in the devzone, instead of adding extra comments?
    Then, other users will help you. I cannot help you with this error.
    Check my settings and post a new question if you still observe the error, please.
    -Best Regards
