I have tried to produce a PWM signal of 33.33KHz at a GPIO pin of nRF52832!The duty cycle of the signal varies bizzaredly even after setting it to 50%!Can anyone help me out! I wanna run an external IC on this clock!Please find the screenshot attached!
PWM.PNGHere is my code:
#include "nrf.h"
#include "nrf_gpio.h"
#include "nrf_drv_rtc.h"
#include "nrf_drv_clock.h"
#include "boards.h"
#include "app_error.h"
#include <stdint.h>
#include <stdbool.h>
#define COMPARE_COUNTERTIME  (3UL)                                       < Get Compare event COMPARE_TIME seconds after the counter starts from 0.
#ifdef  BSP_LED_0
    #define TICK_EVENT_OUTPUT    BSP_LED_0                        < Pin number for indicating tick event.
#ifndef TICK_EVENT_OUTPUT
    #error "Please indicate output pin"
#ifdef BSP_LED_1
    #define COMPARE_EVENT_OUTPUT   BSP_LED_1                               < Pin number for indicating compare event.
#ifndef COMPARE_EVENT_OUTPUT
const nrf_drv_rtc_t rtc = NRF_DRV_RTC_INSTANCE(0); //< Declaring an instance of nrf_drv_rtc for RTC0.
/** @brief: Function for handling the RTC0 interrupts.
 * Triggered on TICK and COMPARE0 match.
static void rtc_handler(nrf_drv_rtc_int_type_t int_type)
{    nrf_gpio_pin_toggle(10);
    if (int_type == NRF_DRV_RTC_INT_COMPARE0)
        nrf_gpio_pin_toggle(COMPARE_EVENT_OUTPUT);
    else if (int_type == NRF_DRV_RTC_INT_TICK)
        nrf_gpio_pin_toggle(17);
/** @brief Function configuring gpio for pin toggling.
static void leds_config(void)
    bsp_board_leds_init();
/** @brief Function starting the internal LFCLK XTAL oscillator.
static void lfclk_config(void)
    ret_code_t err_code = nrf_drv_clock_init();
/** @brief Function initialization and configuration of RTC driver instance.
static void rtc_config(void)
    uint32_t err_code;
    //Initialize RTC instance
    nrf_drv_rtc_config_t config = NRF_DRV_RTC_DEFAULT_CONFIG;
    config.prescaler =0;
    err_code = nrf_drv_rtc_init(&rtc, &config, rtc_handler);
    //Enable tick event & interrupt
    nrf_drv_rtc_tick_enable(&rtc,true);
    //Set compare channel to trigger interrupt after COMPARE_COUNTERTIME seconds
    err_code = nrf_drv_rtc_cc_set(&rtc,0,COMPARE_COUNTERTIME * 8,true);
    //Power on RTC instance
    nrf_drv_rtc_enable(&rtc);
 * @brief Function for application main entry.
    leds_config();
    lfclk_config();
    rtc_config();
    while (true)
        __SEV();
        __WFE();
        __WFE();
