Unexpected event:24
When I try to run the 3 server, 1 client light control example, This is the log that follows:
Client log
<t:          0>, main.c,  318, ----- BLE Mesh Light Control Client Demo -----
<t:          0>, main.c,  108, Initializing softdevice
<t:          0>, nrf_mesh_sdk.c,  109, Initializing SoftDevice...
<t:          2>, nrf_mesh_sdk.c,  118, Ram base: 0x200022D8
<t:         14>, nrf_mesh_sdk.c,  123, sd_ble_enable: app_ram_base should be adjusted to 0x200019C0
<t:         19>, main.c,  116, Initializing mesh stack
<t:        326>, main.c,  123, Enabling mesh stack
<t:        335>, main.c,  141, Setting up access layer and models
<t:        368>, main.c,  265, Configuration of device 0 successful
<t:        371>, main.c,  265, Configuration of device 1 successful
<t:        374>, main.c,  265, Configuration of device 2 successful
<t:         15>, nrf_mesh_sdk.c,  123, sd_ble_enable: app_ram_base should be adjusted to 0x200019C0
<t:        316>, main.c,  123, Enabling mesh stack
<t:        327>, main.c,  141, Setting up access layer and models
<t:        362>, main.c,  265, Configuration of device 0 successful
<t:        365>, main.c,  265, Configuration of device 1 successful
<t:        368>, main.c,  265, Configuration of device 2 successful
21, Button 0 pressed
<t:    2217099>, access.c,  398, TX: [aop: 0x00C1]
<t:    2225628>, access.c,  398, TX: [aop: 0x00C1]
<t:    2234147>, access.c,  398, TX: [aop: 0x00C1]
<t:    2251186>, access.c,  398, TX: [aop: 0x00C1]
<t:    2285261>, access.c,  398, TX: [aop: 0x00C1]
<t:    2353417>, access.c,  398, TX: [aop: 0x00C1]
<t:    2386198>, provisioner.c,  235, Unexpected event: 24.
<t:    2484525>, provisioner.c,  235, Unexpected event: 24.
<t:    2489738>, access.c,  398, TX: [aop: 0x00C1]
Server Log
<t:          0>, main.c,  116, ----- BLE Mesh Light Control Server Demo -----
<t:        290>, main.c,   84, Initializing and adding models
<t:      42532>, nrf_mesh_node_config.c,  175, default case 1
<t:      51804>, nrf_mesh_node_config.c,  175, default case 1
<t:     383650>, nrf_mesh_node_config.c,  175, default case 1
<t:     790197>, nrf_mesh_node_config.c,  175, default case 1
<t:     791040>, nrf_mesh_node_config.c,  175, default case 1
<t:     791764>, nrf_mesh_node_config.c,  175, default case 1
<t:     793330>, nrf_mesh_node_config.c,  175, default case 1
<t:     795546>, nrf_mesh_node_config.c,  175, default case 1
<t:     796230>, nrf_mesh_node_config.c,  175, default case 1
<t:     796993>, nrf_mesh_node_config.c,  175, default case 1
<t:     797832>, nrf_mesh_node_config.c,  175, default case 1
<t:     803277>, nrf_mesh_node_config.c,  175, default case 1
<t:     804049>, nrf_mesh_node_config.c,  175, default case 1
<t:     805336>, nrf_mesh_node_config.c,  175, default case 1
<t:     806105>, nrf_mesh_node_config.c,  175, default case 1
<t:     871640>, nrf_mesh_node_config.c,  175, default case 1
<t:     875284>, nrf_mesh_node_config.c,  175, default case 1
<t:     876031>, nrf_mesh_node_config.c,  175, default case 1
<t:     876132>, nrf_mesh_node_config.c,  112, MESH ASSERT at 0x00023242
Also, what does this error imply: provisioner.c, 235, Unexpected event: 24.
thank you Rahul
