Im using sdk 14.0 and s132 When i add flashwrite codes to my project which has bluetooth communication ,it does not work I wanna send data to flash and i wanna read/write it What is the simplest way to do this
Im using NRF52832.
Thank you
Im using NRF52832.
Thank you
Yes, you are correct. But if you are just storing small amounts of data, then FDS can be overkill. However, I just wanted to provide them with this option as well just in case it suits their needs! Thanks!
I test the code when run the ret_code_t rc = nrf_fstorage_erase( &m_fs, /* The instance to use. / m_fs.start_addr, / The address of the flash pages to erase. / pages_to_erase, / The number of pages to erase. / NULL); / Optional parameter, backend-dependent. */ it shows Address must be aligned to a page boundary.
Can you help me slove the problem?
Hi Syuan, I think it is the address that you defined in the NRF_FSTORAGE_DEF macro. Can I see what address you put in there?
