Application does not start beside DFU bootloader
Hy everybody,
I'm trying to implement DFU bootloader in our custom board, starting from the "bootloader_secure_example", where I just changed leds and button pins in order to adapt them to our board. I successful flashed the soft device and the bootloader, merged with the bootloader settings, and I can perform a dfu firmware update with the nRF Connect, or nRF Toolbox, BLE app but, after the chip reset, nothing happens! No app advertising nor DFU_Targ. If I manually reset the board, pulling down the proper button, it returns to bootloader mode advertising with the DFU_Targ name. Even if I flash the firmware directly with keyl I see the same behavior.
There are no problems if I use just SD+APP (without bootloader).
I suppose the problem could be something related to rom/ram or bootloader settings.
Here are our settings:
SoftDevice: s13_nrf52_4.0.2
SDK: nRF5_SDK_13.1.0_7ca7556
Chip: nRF52832
Bootloader
IROM1 start: 0x78000
IROM1 size: 0x6000
IRAM1 start: 0x20002060
IRAM1 size: 0xDA70
Application
IROM1 start: 0x1F000
IROM1 size: 0x56000
IRAM1 start: 0x20003800
IRAM1 size: 0xC800
Bootloader settings script
nrfutil settings generate --family NRF52 --application-version 4 --bootloader-version 1 --bl-settings-version 1 bootloader_settings.hex
Bootloader DFU Settings:
* File:                 bootloader_settings.hex
* Family:               nRF52
* CRC:                  0xC90C83B3
* Settings Version:     0x00000001 (1)
* App Version:          0x00000004 (4)
* Bootloader Version:   0x00000001 (1)
* Bank Layout:          0x00000000
* Current Bank:         0x00000000
* Application Size:     0x00000000 (0 bytes)
* Application CRC:      0x00000000
* Bank0 Bank Code:      0x00000001
Merged hex files
mergehex --merge bootloader_settings.hex Bootloader.hex --output Bootloader_with_settings.hex
I tried also to set the variable m_dfu_settings_buffer in the file nrf_dfu_settings.c in this way:
uint8_t  m_dfu_settings_buffer[CODE_PAGE_SIZE] __attribute__((at(BOOTLOADER_SETTINGS_ADDRESS)))
                                                   __attribute__((used)) = {NRF_DFU_BANK_VALID_APP};
but when I try to merge bootloader and bootloader-settings .hex files it returns the error
ERROR: The hex files cannot be merged since there are conflicts.
Any suggestion?
Thanks in advance.
Massimo
  • Hi Stian, more better!!!
    Just to notice, in the nRF51 when I perfom a DFU with the nRF Connect app this happens as a unique step whereas in the rRF52 there are two of them. I start the DFU process with my application, then the devise resets switching to dfuTarg and the firmware transfer continues in background.
    Why this difference?
    Thanks a lot!!!
  • Hi Stian,
    we are migrating from nRF5_SDK_13.1.0_7ca7556 to nRF5_SDK_14.2.0_17b948a.
    Now we have some problems with the bootloader again.
    We can flash the application but then the board remains in bootloader mode, advertising as DfuTarg.
    We also tried to perform a DFU with the same result.
    It seams the bootloader doesn't validate the application. But how can we debug it? If we use the macro NRF_DEBUG_ENABLE the compiler returns a no_space error.
    The only things we changed are:
    1. the SoftDevice requirements (from 0x98 to 0x9D) in the command used to generate the DFU packet;
    2. the macro  NRF_SD_BLE_API_VERSION (from 4 to 5) in the keil option for target.
    Is there any other change we have to do during migration?
    Thanks a lot
    Massimo
