NFC_T4T_EVENT_NDEF_READ event not working every time
i am working on an app using Android to read and write an NDEF record using SDK 14 type 4 tag.
I start the process by reading the record with the following Android sequence:
Ndef ndef = Ndef.get(mTag);
ndef.connect();
NdefMessage ndefMessage = ndef.getNdefMessage();
ndef.close();
This produces an NFC_T4T_EVENT_NDEF_READ event on the Nordic side as expected.
After this, i write a record to the NRF52. The record is received. This produces an NFC_T4T_EVENT_NDEF_UPDATED event as expected.
After this, i update the record on the NRF52. Then i read the record with the exact same sequence as before. This time, no NFC_T4T_EVENT_NDEF_READ event is produced, even though my debugs in hal_nfc_t4t.c clearly show, that the record is read and sent properly to the Android device.
Is this some known feature or bug? It seems that only one NFC_T4T_EVENT_NDEF_READ event is produced per session when using Android Ndef library. After the NRF52 NFC interface has been reset, i can get one event. The record read works just fine, and the Android SW receives the correct data. Only the event is missing, which i need for my control flow.
Has anyone else encountered this problem, and found a solution or at least a workaround?
BR, tommi
