somebody help to resolve this problem
Have you tried power cycling the board after programming? Are you using Keil or GCC compiler?
i using keil
i have done power cycling also and i am using keil 5.
I have tested the example multiple times now, and don't see any issues. Plesae try debugging, to see if any functions return non-zero error codes. If this don't work, you should try flashing the hex file found in the zip package as well, to rule out any SDK/compilation issues. The file ble_app_beacon_pca10056_s140.hex contains both application and softdevice.
hi jorgen, if i open the same file with soft device s140_nrf52840_5.0.0-2.alpha_softdevice.hex i am getting errors in softdevice_handler.c and .h file. those files are read only. so i cant modify anything. i dont know why i get these issues. where as ble_app_uart is working fine and i have done neccessary modification for my application. it is still working fine. why the issue is in this file
