nRF5 SDK for Mesh v0.10.1DFU Hangs?
I am working with the nRF-SDK-for-Mesh v0.10.1 I am able to compile and run everything fine. However the DFU example hangs. It looks like a hard fault ( all the LEDs are on).
I am following the guide from the SDK docs here:
infocenter.nordicsemi.com/.../md_doc_getting_started_dfu_quick_start.html
I am using:
PCA10031, nrf51422, s130
SoftDevice: /external/softdevice/s130_2.0.1/s130_nrf51_2.0.1_softdevice.hex
Bootloader: /bin/bootloader_serial_xxAC.hex
DFU: /build/examples/dfu/dfu_nrf51422_xxAC_s130_2.0.1.hex
When running the DFU example It hangs during mesh stack initialization in "nrf_mesh_int()" from "nrf_mesh.c" around line 145 I believe in the "core_tx_init()" function. I have tried the serial example which has similar init code and it works fine (except it doesn't except DFU commands because for some reason it is linking the "_weak" functions in "nerf_mesh_weak.c" instead of the real ones (I am posting this in another question).
Here is the RTT Trace:
<t:        265>, main.c,  162, ----- Bluetooth Mesh DFU Example -----
<t:        281>, nrf_mesh_sdk.c,  181, Initializing softdevice
<t:          4>, nrf_mesh_sdk.c,  122, Initializing SoftDevice...
<t:         18>, nrf_mesh_sdk.c,  131, Ram base: 0x200022D8
<t:         84>, nrf_mesh_sdk.c,  140, sd_ble_enable: app_ram_base should be adjusted to 0x20001900
<t:        110>, nrf_mesh_sdk.c,  191, Initializing mesh stack
Thank you!
Here is the stack trace:
Temporary breakpoint 1, main () at /Users/jasonpeterson/Documents/nrf5_SDK_for_Mesh_v0-2a/examples/dfu/src/main.c:153
153	{
(gdb) continue
Continuing.
^C
Program received signal SIGTRAP, Trace/breakpoint trap.
sleep_forever (pc=pc@entry=1) at /Users/jasonpeterson/Documents/nrf5_SDK_for_Mesh_v0-2a/examples/nrf_mesh_sdk.c:64
64	    while (pc)
(gdb) backtrace
#0  sleep_forever (pc=pc@entry=1) at /Users/jasonpeterson/Documents/nrf5_SDK_for_Mesh_v0-2a/examples/nrf_mesh_sdk.c:64
#1  0x0001b88e in HardFault_Handler () at /Users/jasonpeterson/Documents/nrf5_SDK_for_Mesh_v0-2a/examples/nrf_mesh_sdk.c:85
#2  <signal handler called>
#3  0x00026c74 in timer_on_ts_begin (timeslot_start_time=0) at /Users/jasonpeterson/Documents/nrf5_SDK_for_Mesh_v0-2a/mesh/core/src/timer.c:304
#4  0x00026f92 in on_ts_begin (p_timeslot=0x200038e0 <m_current_timeslot>) at /Users/jasonpeterson/Documents/nrf5_SDK_for_Mesh_v0-2a/mesh/core/src/timeslot.c:180
#5  0x0002706c in handle_extend_end (p_timeslot=p_timeslot@entry=0x200038e0 <m_current_timeslot>, success=success@entry=true)
    at /Users/jasonpeterson/Documents/nrf5_SDK_for_Mesh_v0-2a/mesh/core/src/timeslot.c:317
#6  0x000270fa in radio_signal_callback (sig=<optimized out>) at /Users/jasonpeterson/Documents/nrf5_SDK_for_Mesh_v0-2a/mesh/core/src/timeslot.c:396
#7  0x0001a2b0 in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?)
