I am a freshman. And I am doing some research on BTLE by nRF51822-EK. I want to get RSSI. Could you please tell me if there is a reference code or project in SDK? Is there any book about development of BTLE? Please tell me. Many thanks.
Hi
For reference please have a look at the attached example. It adds RSSI measurements to the nRF51822 Evaluation kit HRS example, and changes the value of the evaluation kit LED based on the RSSI.
Best regards Torbjørn
Thank you so much! I think you are so great! I have get the result like this: [16:18:41.0] Received Read Response, handle: 0x0003, value (0x): 48-52-4D-5F-45-4B-5F-52-53-53-49 so which number is the RSSI? Maybe this is my last question. Many thanks.
Many thanks for you kindly reply. You are a great person.
The attached is what I have seen. So which one is the result of RSSI. or I should write some command in somewhere.
This is my last question.
Thank you. Please reply soon.
please look at the next two comment. Thank you!
As you can see in the code, this example does not transmit the RSSI over the air in any way, so you can not read it in Master Control Panel. Instead it outputs the RSSI value on the LEDs. Please see line 657 in main.c and onwards.
