ZIP file must contain application, softdevice or bootloader
Hello, I'm building an Android application for DFU. I have a zip file and am downloading it and getting the content URI after download and using it in starter.setZip(contentUri). But I am getting this exception:
11-09 18:52:58.492 31020-31090/com.example.nikitha.run_2 E/DfuBaseService: An exception occurred while calculating file size
        java.io.IOException: The ZIP file must contain an Application, a Soft Device and/or a Bootloader.
        at no.nordicsemi.android.dfu.internal.ArchiveInputStream.<init>(ArchiveInputStream.java:245)
        at no.nordicsemi.android.dfu.DfuBaseService.openInputStream(DfuBaseService.java:1184)
        at no.nordicsemi.android.dfu.DfuBaseService.onHandleIntent(DfuBaseService.java:939)
        at android.app.IntentService$ServiceHandler.handleMessage(IntentService.java:68)
        at android.os.Handler.dispatchMessage(Handler.java:102)
        at android.os.Looper.loop(Looper.java:154)
        at android.os.HandlerThread.run(HandlerThread.java:61)
  • Sorry for the delay! Here is my FIX : The MAC address of the device changed when it went into DFU mode and a scan was needed just before the update. I was pulling the address from a previously built device table that had a list of devices and corresponding device addresses from the initial scan. My bad! But I'm "just" a mobile dev, so was not able to catch this. Thanks for all your help Hung!
