pairing procedure "authentication requirement"
Thank you for reading my question.image description
peripheral project :ble_app_hrs_rscs_relay,SDK14.1 ,S132
client project: another manufacturer's soc
I set peripheral peer manager to MITM = 1, IO cap = BLE_GAP_IO_CAPS_KEYBOARD_DISPLAY
client's MITM = 0, IO cap = BLE_GAP_IO_CAPS_NONE
Through sniffer capture packets found that pairing procedure can be normal, and finally used should be Just work way to generate STK.
BLUETOOTH SPECIFICATION Version 5.0 | Vol 3, Part H page 2315
"If the key generation method does not result in a key that provides sufficient security properties then the device shall send the Pairing Failed command with the error code "Authentication Requirements."
Question 1: Is "sufficient security properties" here referring to the MITM field in the pairing request / pairing response? Just work generated STK is not satisfied with the safety requirements of peripheral?
BLUETOOTH SPECIFICATION Version 5.0 | Vol 3, Part H page 2346
"value: 0x03
Name: Authentication Requirements
Description: The pairing procedure can not be performed as authentication requirements can not be met due to IO capabilities of one or both devices "
Question 2: If my understanding of Question 1 is correct, why does peripheral not send Pairing Failed with "Authentication Requirements"? Or is my understanding of Question 1 wrong?
  • Thank you for your patience, thank you very much.
    According to my understanding: After the Central send pairing request, peripheral will get BLE_GAP_SEC_STATUS_SUCCESS, regardless of MITM, and will not initiate pairing failed, I guess this is what you want to let me know
    BLUETOOTH SPECIFICATION Version 5.0 | Vol 3, Part C page 2071
    "If an authenticated pairing is required but only an unauthenticated pairing has occurred and the link is currently encrypted, the service request shall be rejected with the error code "Insufficient Authentication." "
    But in the case of attribute permisson restrictions, which is another idea you mentioned, is it the same? That is, if an NO MITM's encrypted connection, central access a Level 1 mode3 attribute, what happens? peripheral will also get BLE_GAP_SEC_STATUS_SUCCESS and softdevice send "Insufficient Authentication" to central? I feel so strange, it should be my understanding is not clear.
  • Yes.
    Yes. Insufficient Authentication will be received if the client tries to access and attribute with a higher security level requirement than the connection is currently in.
  • As you said, from pm_evt_handler's p_evt parameter, I'm not even able to know who caused PM_EVT_CONN_SEC_SUCCEEDED event, perhaps caused by pairing request from client, or client access to a higher security attribute, although the latter server would send Insufficient Authentication to the client, but in pm_evt_handler of peripheral's code i can not know this, and I would not be able to do a disconnect for the latter case because I do not know what is the current case.
