Avoid "Bluetooth pairing request" alert on iOS
Hi.
I have an application that needs a low security encryption. Therefore I want to use "Just works" encryption. The pairing process is assumed to be in a "safe" place.
But iOS are prompting with the "Bluetooth pairing request" alert before every connection. And I thing that it is very annoying and irrelevant. I can accept the first alert, but not later.
I am using 7.2 softdevice on a nRF 51822.
Is it possible to suppress this message either from the BLE device (or perhaps in the iOS App).
Kasper
  • Thank you shibshab, you have been very helpfully, but I believe that your last sentence is the most important: "Also note that this requires support on the iOS side..." I still get the "Bluetooth pairing request" :-( I believe that I have to give up, it is not possible.
    Compared to the UART example in 8.0 I have done following changes
    changes.txt
  • @Kasper: If you pass NULL as the p_sec_keyset, then it will be only pairing with no bonding. No longterm keys will be exchanged and you will see the pairing request popup everytime. The p_sec_keyset is where you will have the keys after the bonding process is done (BLE_GAP_EVT_AUTH_STATUS event).
    I would suggest you to have a look at the ble_app_template example we have in SDK v8.0. In this example we handle the bonding without device manager and could be a good example to refer. Note that in that example, we don't store LTK in flash so if you reset the chip, the LTK will go missing. You will have to erase bond on the phone to reconnect and rebond.
  • @shibshab: on my device when I sniffed the traffic with Wireshark, on SCAN_RSP I always get Scan Response Data: Other devices I tested have some data in this field. My device is working, but I think there is some wrong coding that causes this. Maybe because an incorrect order of my advertising data?
