Hi, I followed the tutorial to Debug with Real Time Terminal on Keil.
fatal error: file sdk_config.h not found.
I have followed the tutorial as precisely as I can, maybe I'm doing something wrong. Please help.
Thanks in advance, Emine
The file is in my SDK folder, I can see it and edit it. How can I add the path into my project?
In keil:
Go to "Options for target" -> Select the C/C++ tab -> Edit "Include Paths" and insert the path to your config header file.
it looks like it's already there: ..\config
This error appears in the left corner of uVision window, under "Build Output" Whenever i place the mouse in the text editor...
That's weird.
Are you using the peripheral or ble_peripheral blinky example?
You could try to add the direct path (like the one in my previous comment) to the file, instead of the project directory relative path (..\config).
Also, the SDK folder should be placed as close to the base drive folder to avoid path lenghts exceeding the limit (247 characters).
