Hello Sir,
We are using nRF52832 chip and Softdevice is S132. Is it possible to sample an analog signal using internal ADC conversion using 4096Hz?. Its look like it does at 3900Hz.
Thanks in Advance..
Hello Sir,
Thanks in Advance..
I measure the current using multi meter which is connected serial of positive power supply. I measure 5.78mA current during advertising only when i reading ADC value at that it goes to 6-7mA with BLE connectivity in android apps. In new RTC code i am not set sampling rate only set frequency and CC value is 32768 and 8. So sir Can you guide me how i can reduce this high current consumption because my device is operate on AA battery cell. For long battery life is important for me. In my new RTC program where i need to define sampling rate, and also How i can control EasyDMA for less current consumption. You saying are upload my main program.
You might need to get some better equipment than a multimeter for doing presice measurements of these quickly switching currents. I would recommend the Power Profiler Kit. I did some measurements on the ble_app_uart__saadc_timer_driven__scan_mode code with timer and RTC, and did not see large differences in current (TIMER - RTC). The timer in the example runs on PCLK1M, which gives the timer a run current of 5 µA typical + HFINT Clock run current of 60 µA. The run current of RTC is 0.1 µA typical, pluss run current of LFCLK of 0.25-1 µA. There are some differences here, but compared to the total consumption of the application, this is not the part you should be concerned about. The ~2mA base current of the consumption comes from the EasyDMA current. You should consider if you need such a high sample frequency in your application, or if you could lower this and shut down the SAADC between sampling. This will save you much current.
