Hi!
nRF52. S132, SDK13.
I try to use ble_dfu_send_hex example.
- what shoul I do first? via nrf gostudio load SD. correct?
Which SD? from this folder (dfu_test_softdevice_s132) Or usual SD (s132_nrf52_4.0.2_softdevice)
- what should I do next?
Hi!
nRF52. S132, SDK13.
ok. I'll try make your steps. I'll write here what will unclear.
I try to make all steps from your manual. With keys. First- step B. you wrote: The bootloader is located at \examples\dfu\bootloader_secure_ble below: in the step B1- how to build the bootloader. What I should do? take bootloader from example or build new?
additional. I can't make step B1. when I type ...\micro-ecc\nrf52_keil\armgcc answer is the system can't find this path.. means can't to create.
By "build" I mean compile the bootloader example. Please try to follow the steps. Have you downloaded uECC from github, and paste it into your SDK as mentioned in the blog ? What do you have at \external\micro-ecc\nrf52_keil\armgcc ?
Hi! I try to follow step by step your manual. I already copyed uECC in to SDK like described. Now I try make "make" command. I don't understand- what should I do with The bootloader is located at \examples\dfu\bootloader_secure_ble ?
