help needed to debug nrf51822 application?
Hello all,
I am developing application for humidity measurement using nrf51822 evaluation board which uses custom services which i have developed. I have already tested example applications given in sdk. Also my humidity application was able to run upto service discovery. After service discovery the connection gets terminated (reason: BTLE_CONNECTION_TIMEOUT ) due to received packet.<HciEvent: eventCode=0x0A>.
I am debugging my application in Keil µVision. Is single stepping is allowed? I am noob towards debugging. Can anybody help how one should debug application step by step?
  • Thanks John. I will check assert handler and will update about it. Meanwhile i was searching about connection parameters and saw my logs. I also suspect that error occurred when packet was not able to receive on connection parameter update call. And then hci event [BTLE_EVENT_DISCONNECTION_COMPLETE] occurs. Do you have any Idea about what is the issue?
