Hi, around July Nordic Semiconductor released this SDK which featured examples of BLE mesh that uses a dev board as provisioner.
This program is OK, but it has zero possibility of switching the role between provisioner and provisionee, moreover, since it uses advertising packets, it is impossible to communicate with any node using GATT, which requires advertising communication prior to establishing the GATT connection.
So how are things now? I haven't been following everything for a while. ideally, this is what I want:
I want to be able to provision an entire mesh network using a random node of the mesh network.
And this is how I think it could be done:
We all know it's quite impossible at this point to use iPad or Android phone as provisioner. So it would be great if I can connect to any node first using advertising packets, then establish GATT (you know, the usual), and then I can send some commands over using GATT which turns this random node that I just connected into a provisioner, and then provision the entire network, once I'm done, this node that I just disconnected will be restored to its previous state, and then if there is a need, I can do this routine again on a different random node.
So my questions:
- Is what described above available now?
- If not, is there a plan to implement what I described? When will it be ready (if it can be revealed)?
- Please kindly provide relevant information.
