I have a binary data file that I would like to program in flash at defined address on a nrf52 device
Which tool do you advise that generate hex intel file format by providing binary data filename and base address
Thanks
Thanks
Read manual. Btw. one would wonder why doing it so complicated when basically every toolchain today supports direct Intel HEX output?
I think original Makefile.common in the examples also use arm-none-eabi-objcopy to convert .out to .hex. I checked the link you shared already, the following options didn't make a difference, still flashing to 0x0. Now I am contemplating manually changing the hex file I created.
--set-start=val] [--adjust-start=incr] [--change-addresses=incr] [--change-section-address sectionpattern{=,+,-}val]
