i2c driver from scratch using direct register access
        void i2c_init(unsigned char addr)
          NRF_TWI0->PSELSCL=27;
          NRF_TWI0->PSELSDA=26;
          NRF_TWI0->ADDRESS=addr;
          //TWSR = 0x00;
          //NRF_TWI0->FREQUENCY = 0x01980000;   //100 KHz
          NRF_TWI0->FREQUENCY = 0x06680000;     //400 Khz
          NRF_TWI0->ENABLE = 0x00000005;
        void i2c_startTX()
          NRF_TWI0->TASKS_STARTTX=1;
        void i2c_startRX()
          NRF_TWI0->TASKS_STARTRX=1;
        void i2c_write(unsigned char data)
          NRF_TWI0->TXD=data;
          while(NRF_TWI0->EVENTS_TXDSENT==0){}
          NRF_TWI0->EVENTS_TXDSENT=0;
        unsigned char i2c_read(void)
         unsigned char data;
         while(NRF_TWI0->EVENTS_RXDREADY==0){}
         NRF_TWI0->EVENTS_RXDREADY=0;
         data = NRF_TWI0->RXD;
         return data;
        void i2c_stop(void)
          NRF_TWI0->TASKS_STOP=1;
          while(NRF_TWI0->EVENTS_STOPPED==0){}
          NRF_TWI0->EVENTS_STOPPED=0;
        void eeprom_init()
          unsigned char cntr;
          i2c_init(0x50);  // EEPROM i2c address
          i2c_startTX();
          i2c_write(0x00);
          for(cntr=0;cntr<=15;cntr++)
            i2c_write('A' + cntr);
          i2c_stop();
          nrf_delay_ms(10);
          serial_write_string("EEPROM initialisation completed !!\n\r");
        void eeprom_read(unsigned char addr)
          unsigned char boo[17]={'\0'};
          unsigned char cntr;
          int data;
          i2c_startTX();
          i2c_write(addr);
          //i2c_stop();
          i2c_startRX();
            boo[cntr]=i2c_read();
          i2c_stop();
          serial_write_string(boo);     //<-- I'm talking about this
          serial_write_string("\n\r");
I've written basic i2c functions as mentioned above to access AT24C04 EEPROM.
This EEPROM drivers works for me but "serial_write_string(boo)" from eeprom_read() prints -> PABCDEFGHIJKLMNO.
Ideally it should print -> ABCDEFGHIJKLMNOP
I used same code on Arduino & it give me correct output. Why nrf52840-pdk is giving me such strange output ?
I've already solved this issue by modifying my eeprom_read() function as follow
  unsigned char cntr;
  int data;
  i2c_startTX();
  i2c_write(addr);
  //i2c_stop();
  i2c_startRX();
  for(cntr=0;cntr<=14;cntr++)
  i2c_stop();
  boo[15]=i2c_read();       // read last byte after sending i2c_stop()
This function accurately prints what I'm expecting that is "ABCDEFGHIJKLMNOP"
could someone explain me, why this so ?
How to send NACK with last byte while reading multiple bytes from i2c device ? (Generally we send ACK when reading byte is not last byte & send NACK when we request last byte to read)
nrf528xx data-sheet does not allow me to do this. Why ?
I don't wanna use APIs provided by SDK. So kindly don't give me that solution.
Thank You !!
  • [issue is solved !!]
    I found my mistake. Here I'm presenting my ( tested on nRF52840-PDK ) corrected version .....
        //TWSR = 0x00;
    void i2c_startTX()
    void i2c_startRX()
        NRF_TWI0->TXD=data;
    unsigned char i2c_read(unsigned char nack)
        unsigned char data;
        if(nack==1)
        return data;
    void i2c_stopTX(void)
    void i2c_stopRX(void)
    void eeprom_init()
        unsigned char cntr;
        i2c_startTX();
        i2c_write(0x00);
        i2c_stopTX();
        nrf_delay_ms(10);  // delay for EEPROM write
        unsigned char cntr;
        int data;
        i2c_startTX();
        i2c_write(addr);
        //i2c_stop();
        i2c_startRX();
            if(cntr != 15)
                boo[cntr]=i2c_read(0);
                boo[cntr]=i2c_read(1);
        i2c_stopRX();
