NRF52 Timing Accuracy
I'm developing an accurate and low drift millisecond-resolution timer on the NRF52. I'm limited to the resources on the NRF52 itself. Details of the system:
  • Initialise TIMER0 to be clocked from the main crystal (16MHz 10 ppm, using the PCA10040 to test).
  • Configure TIMER0 to generate an interrupt every 1ms, using the compare match 0.
  • Every 1000ms, a pin on the NRF52 is toggled (NRF_PPS). [EDIT: this is only to validate the timer accuracy against the GPS 1PPS]
  • The TIMER0 interrupt is set as APP_IRQ_PRIORITY_HIGH.
In order to benchmark the accuracy of the timer, I use a GPS 1PPS output (stated to be accurate to <40ns 95% of the time). The test program waits for the rising edge of the GPS_PPS. Once this is received, it starts the milli-second timer. Using an oscilloscope, one channel is triggered on the rising edge of the GPS_PPS. Another channel displays the NRF_PPS. The drift of the millisecond timer is the difference between the NRF_PPS and the GPS_PPS.
I've found that if I set the compare match value to how it should be (NRF_TIMER1->CC[0] = 1000
  • 1), the drift is 750.0 ms over 4 minutes. Meanwhile if I tweak the match value, the best I can get the drift down to is 133.4ms over 4 minutes ((NRF_TIMER1->CC[0] = 1000 - 1 - 2). This is drifting well outside the spec of the onboard crystal. A 10 ppm crystal should only drift 2.4ms over 4 minutes!
Questions:
  1. Is generating interrupts on the compare match the best way to keep a millisecond-resolution timer value?
  2. Why is the compare match value drifting so much when I set it to how it should be?
  3. Why is the timer drifting well outside of the spec of the 16MHz crystal on the PCA10040? The equivalent spec of my millisecond timer after tweaking is 3125 ppm! After tweaking it is 560 ppm (but still unacceptably high).
My application is also going to use BLE (advertising, central and peripheral connections at the same time!). From what I've read, the worst t_radio (Table 25) is 5.5ms in my use-case. Does this mean that I'll miss interrupts some 1ms timer compare interrupts? Or am I reading the s132 v4.0.2 SD specification incorrectly? What is the longest time at which interrupts with APP_IRQ_PRIORITY_HIGH level are unable to be serviced while using BLE?
Notes:
  • The port toggling in the TIMER1_IRQHandler is not likely to influence the results. I've measured the ISR to take 978ns (excluding the interrupt context switching...).
  • I could change to clock the timer from the 32kHz crystal, but would like to figure out why the current timer clocked from the XTAL is drifting so much.
  • I'm using NRF52 modules with have an onboard XTAL. I can't replace this with a TCXO but the application does not require accuracy better than 10 ppm.
  • I'm using the s132_nrf52_4.0.2 soft device. In the above test, I have not enabled the soft device, but would need to when my application is doing BLE.
  • I've done something similar with my STM32-based projects. With an ordinary 10ppm XTAL, I've observed a drift of 1ms over 4 minutes, which equates to 4.2 ppm.
Test program: www.dropbox.com/.../nrf_timer_accuracy_test.c
  • RK, I think your suggestion to check the clock source is the answer here. (I usually have the soft device running, but for the purpose of a small test program I neglected to switch over to the HF crystal). I've retested the timer and it is drifting at 13.4 ppm. I'll stick with the current compare match feature, mainly because I also use this interrupt to trigger timed callbacks.
  • I've since updated my test program. I've also reduced the capture compare interrupt frequency to 20Hz, so should not have any missing interrupts while the radio is being operated. If I enable the HF XTAL via the "registers", I observer a drift of 3.21ms over 4 minutes. However, if I enable the HF XTAL via enabling the soft device, the drift is much worse - 193ms over 1 minute! Suggestions? Updated test program can be found here: www.dropbox.com/.../nrf_timer_accuracy_test2.c
  • I've solved the drifting issue. I've tested the accuracy of my milli-second resolution timer and it is 13.4 ppm, similar to that of the 10 ppm HF XTAL on the NRF52 dev board. Key findings:
    • You must call "sd_clock_hfclk_request" and wait for confirmation that it is running via "sd_clock_hfclk_is_running". The call to "SOFTDEVICE_HANDLER_INIT" will set the system to use the HF CLOCK. However, the resulting timing suggests that the system is still using the internal RC oscillator if the aforementioned setup is not done afterwards. This is not very clear in the examples and I recommend that future examples explicitly do this, ideally not buried away in some optional module that the end user may not use in their application.
    • When using the TIMER module in the timer mode, you need to get the current timer value via issuing a capture on a different channel than that of your compare. The internal timer count is then immediately accessible on the appropriate CC register. [This is
    • The correct value for the compare channel is the (value), not the (value - 1). This is slightly odd as I'd assume the SHORTS mechanism reloads the timer value to 0 and the timer counter increment on the next clock.
    I have also reduced the interrupt frequency of the compare to 20Hz (originally 1000Hz). This is to ensure that no interrupts are lost while the CPU servicing BLE radio tasks. In my application I also use this compare interrupt for timed callback functions. I'll need to increase the interrupt frequency for finer controlled timed callbacks but run the risk of missing interrupts while using BLE.
    The updated example program can be found here: www.dropbox.com/.../nrf_timer_accuracy_test_final.c
  • I was thinking about your previous post overnight and thought of sd_clock_hfclk_request() this morning, but you figured it out yourself before I got there. Good stuff, the softdevice code is written to be power aware and has to be pressed a little to keep everything running.
  • You are likely subject to the HFCLK ramp-up time. Manually requesting the HFCLK will keep it up until you release it.
