Any special steps for first use - n52832
Is there anything special required to make a n52832 work the very first time the chip is programmed? Fuses to set, etc?
I'm new to nordic chips and I was handed a board with a working chip, I program it and it works fine. I was handed a new board, same design and same chip, and using the same code the chip programs fine but does not run, and draws no current. The low frequency clock crystal (32kHz) is not oscillating and since both pins of the crystal connect to the processor (XL1, XL2 pins) I'm trying to determine if it's due to a hardware problem, or a step that I missed programming the chip for its first use. I'm just flashing code to it using a Segger through uVision IDE.
