BLE DFU (SDK 14.2) - fstorage jobs queued but never executed
Hi there
I did an upgrade of the bootloader from SDK 12.2 to SDK 14.2. I am using the nrf52832 chip. It is basically the same as the secure BLE DFU example from the SDK plus a few things like LED signaling and buzzer control. Nothing really serious and these things should not cause any troubles (I guess).
I managed to get the device to advertise and I can connect through BLE and start the DFU. Prevalidation succeeds, so the application firmware packet seems to be correct too. I also printed the received data to the debugging interface and there is indeed data coming, but eventually the fstorage queue runs full and the DFU is aborted. If I increase NRF_FSTORAGE_SD_QUEUE_SIZE to 1024 the data transmission succeeds but in postvalidation I get a hash error.
Next I checked if data is actually written to flash by reading back with "nrfjprog --memrd ..." and it seems there are only FFFFFF in there, so nothing gets written. I added some calls to nrf_dfu_flash_store() in nrf_dfu_init() and it seems, that when I use NVMC as a backend the data is written and events are triggered but when SD backend is used, only the first fstorage job is executed and no event is triggered. Someone got a pointer what could be the issue here?
Here is the relevant code snippet:
uint32_t nrf_dfu_init(void)
	Status ret_val = NRF_SUCCESS;
	uint32_t enter_bootloader_mode = 0;
	NRF_LOG_DEBUG("In real nrf_dfu_init");
	nrf_dfu_settings_init(false);		// use NVMC
	NRF_WDT->RR[0] = WDT_RR_RR_Reload;  // Pat the watchdog
	clock_init();
	timers_init();
    // no problem if I call nrf_dfu_flash_store() from here with NVMC backend active
	// Continue ongoing DFU operations
	// Note that this part does not rely on SoftDevice interaction
	ret_val = nrf_dfu_continue(&enter_bootloader_mode);
	if(ret_val != NRF_SUCCESS)
		NRF_LOG_INFO("Could not continue DFU operation: 0x%08x");
		enter_bootloader_mode = 1;
	// Check if there is a reason to enter DFU mode
	// besides the effect of the continuation
	if (nrf_dfu_enter_check())
		NRF_LOG_INFO("Application sent bootloader request");
	nrf_power_gpregret_set(0);
	if(enter_bootloader_mode != 0 || !nrf_dfu_app_is_valid())
		scheduler_init();
		// Start the inactivity timer.
		ret_val = app_timer_start(nrf_dfu_inactivity_timeout_timer_id,
								  APP_TIMER_TICKS(NRF_DFU_INACTIVITY_TIMEOUT_MS),
								  NULL);
		if (ret_val != NRF_SUCCESS)
			NRF_LOG_ERROR("Could not initialize inactivity timer");
			return ret_val;
		// Initializing transports
		ret_val = nrf_dfu_transports_init();
			NRF_LOG_INFO("Could not initalize DFU transport: 0x%08x");
			return ret_val;
		(void)nrf_dfu_req_handler_init();
		 * TEST
			uint32_t test = 0x01234567, test2 = 0x89ABCDEF;
			NRF_LOG_INFO("TEST STORE DATA");
			nrf_dfu_flash_store(0x23000, &test2, sizeof(test2), NULL);    // this gets written but event handler is never triggered
			nrf_dfu_flash_store(0x23004, &test, sizeof(test), NULL);    // only queued but not written
		 * TEST ENDE
		// This function will never return
		NRF_LOG_INFO("Waiting for events");
		wait_for_event();
		NRF_LOG_INFO("After waiting for events");
	if (nrf_dfu_app_is_valid())
		if (g_SignalProvider != NULL) {
			g_SignalProvider->Uninit();
		NRF_LOG_INFO("Jumping to: 0x%08x", MAIN_APPLICATION_START_ADDR);
		nrf_bootloader_app_start(MAIN_APPLICATION_START_ADDR);
	// Should not be reached!
	NRF_LOG_INFO("After real nrf_dfu_init");
	return NRF_SUCCESS;
Here is the relevant NRF_LOG output
 0> <info> BL_main: Inside main
 0> <debug> BL_main: Starting Bootloader {VM}.{vm}{VS} (0.0.0.0): ...
 0> <debug> app: In nrf_bootloader_init
 0> <debug> app: in weak nrf_dfu_init_user
 0> <debug> nrf_dfu: In real nrf_dfu_init
 0> <debug> nrf_dfu_settings: Running nrf_dfu_settings_init(sd_irq_initialized=false).
 0> <debug> nrf_dfu_flash: Calling nrf_dfu_flash_init(sd_irq_initialized=false)...
 0> <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
 0> <debug> nrf_dfu_settings: Resetting bootloader settings.
 0> <debug> nrf_dfu_settings: Writing settings...
 0> <debug> nrf_dfu_settings: Erasing old settings at: 0x0007F000
 0> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007F000, len=1 pages), queue usage: 1
 0> <debug> nrf_dfu_flash: Flash erase success: addr=0x0007F000, pending 0
 0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007F000, len=0x1B8 bytes), queue <debug> nrf_ble_dfu: Enabling SoftDevice.
 0> <debug> nrf_ble_dfu: SoftDevice enabled.
 0> <debug> nrf_ble_dfu: nrf_dfu_settings_adv_name_is_valid FALSE
 0> <debug> nrf_ble_dfu: Regular adv name
 0> <debug> nrf_ble_dfu: #### Advertising NO BONDING ####
 0> <debug> nrf_ble_dfu: Finished initializing BLE DFU transport
 0> <debug> app: After nrf_dfu_transports_init
 0> <debug> nrf_dfu_flash: Calling nrf_dfu_flash_init(sd_irq_initialized=true)...
 0> <debug> nrf_dfu_flash: Initializing nrf_fstorage_sd backend.
 0> <info> nrf_dfu: TEST STORE DATA
 0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023000, len=0x4 bytes), queue usage: 1
 0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023100, len=0x4 bytes), queue usage: 2
 0> <info> nrf_dfu: Waiting for events
I also believe that I configured the SDK right. Some relevant things from sdk_config.h
#define NRF_SDH_DISPATCH_MODEL 		        1
#define NRF_SDH_SOC_ENABLED 				1
#define NRF_SDH_BLE_ENABLED 				1
#define NRF_DFU_INACTIVITY_TIMEOUT_MS 		120000
#define NRF_DFU_POST_SD_BL_TIMEOUT_MS 		10000
#define FLASH_BUFFER_LENGTH 				256
#define NRF_FSTORAGE_SD_QUEUE_SIZE 		    1024
#define NRF_FSTORAGE_SD_MAX_RETRIES 		8
#define NRF_FSTORAGE_SD_MAX_WRITE_SIZE 	    20
Why is there no event triggered and obviously no data written to flash with SD as a fstorage backend? What do I miss, please help me before I loose the rest of my hair here :)
Kind regards Karl
  • @Kyle: sorry it was for Carlos, thanks for reporting the issue, we will have a look at the cases.
  • Thank you for all your answers and sorry for the late reply. We are at vacation till 8th January at the moment, so I will try your suggestions as soon as I am back at the lab.
    @Kyle Krueger: you suggest to download softdevice v5.1 from Nordic servers and use it instead of v5.0? Also I have to say, It is not a Problem to boot into DFU mode, advertising is working and I can connect to DfuTarg with nrfConnect and our custom app. Also transmission of the data seems to be correct but it is never written to flash as i believe because reading memory with nrfjprog --memrd gives just FFFFF...
  • @Hung Bui: not exactly. Yes I use SD v5.0 and the bootloader from SDK14.2 but with a few modifications for signaling through a buzzer and LEDs. I flash SD + Bootloader without any app at the moment and then I am trying to do DFU through our custom app, which is also based on the Nordic examples as I am told. I can't tell how much they changed because I am not the phone app developer, but I believe they also did just minor changes because the Firmware suggests this. I will have a look at your blog when vaccation is over.
