Hello I would like to know when nrf51822 (SDK v12.3 with SD S130 ) advertising timeout and system goes to sleep , how could I retain the ram data so the MCU could work properly when it is woke up by other event? Thanks.
Or you mean i should create a customized version of ble_advertising_on_ble_evt() and call it instead?
Hi
When configuring the ble_advertising module you will usually register an event handler in the application, that allows you to change the advertising behavior without having to change the module itself.
In the standard examples this function is called on_adv_evt(..):
uint32_t err_code;
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
Best regards
Ok, understand thanks!
