Main differences between 52810 and 52832?
Today I read about the new nrf52810 and I want to know about its main differences with the nrf52832.
I see a lower power consumption for the 52810 vs 52832 and no NFC on the 810, is this correct? Also there are other changes?
Thank you!
  • Oh.
    So if your code delays using a constant number of instructions (say NOP) then code that works on the nRF52832 might not work on the nRF52810.
    If you test on the NRF52DK and disable the instruction cache, does the CoreMark score match the score on a native nRF52810? A developer must ensure that instruction cache is disabled, if they want the timing to match?  I don't guess that defining DEVELOP_IN_52832 will ensure the instruction cache is disabled.
    Is this timing issue why S132 does not work on the nRF52810?  That is, does a Softdevice require instruction cache to be in a certain enable state, and using Softdevice disallow modification of that state while Softdevice is enabled?
  • The DEVELOP_IN_52832 preprocessor define will disable workarounds for erratas that are specific to the nRF52810 and  enable workarounds specific for the nRF52832, see the system_nrf52810.c file in one of the pca10040e projects. The Cache is by default disabled on the nRF52832 and must be explicitly enabled in SW, so this should only be an issue if you have enabled it in your pca10040e project.  However, you are correct, you could potentially run into race conditions if you develop on the nRF52832 with the cache enabled.
    I am afraid that we do not have CoreMark measurements for the nRF52832 with the cache disabled, but I would assume that it is comparable to the nRF52810.
    No,  the S132 SoftDevice implements workarounds for the erratas for the nRF52832, which may lead to undefined behavior if run on a nRF52810. Also note that the S132 has not been production tested on the nRF52810.
  • Is s112 production tested on the NRF52DK, i.e. as a pca10040e (emulation) project?   With or without instruction cache enabled on the NRF52832?
    Just to be absolutely clear about how to develop for nRF52810 with s112 using the NRF52DK.  Sorry if I have been lax in searching the documents, but I did not see s112 or instruction cache discussed in the Infocenter  nrt52810 user guide   topic=%2Fcom.nordic.infocenter.sdk5.v14.1.0%2Fnrf52810_user_guide.html
  • Yes, the S112 is production tested on the nRF52832 (hence also the nRF52 DK) with the instruction cache disabled.
