How to develop a GATT Client application?
I have a central device , that acting as a gatt server. the service is customize, and 128bit- primary serivice UUID ,its characteristics' UUIDs(128bit) are all known, how to discovery the service and characteristics in nrf51822 peripheral? I don't find any examples that has above function.
    Thanks for clear response. One further question for same use case.
    How can you subscribe to GATT Servers discovered characteristic with "Indicate" or "Notify" ?
    I saw the Message Sequence Charts "GATTC Handle Value Indication" and "Notification", but missing the part how to enable GATT Server to send this values. I could not see any GATTC function to do it.
    Best Regards.
  • Hi Joe,
    You will need to enable notifications and/or indications by writing to the remote device's Client Characteristic Configuration Descriptor (CCCD) for the relevant Characteristic, setting a "1" in the relevant bits.
    Before that of course, you will have to discover the service, characteristic and descriptors that are of interest to you, so the procedure would be a sequence of the following in the Message Sequence Chart procedures:
    GATTC Primary Service Discovery GATTC Characteristic Discovery GATTC Descriptor Discovery GATTC Characteristic or Descriptor Value Write
    You can find example code in the SDK that implements this is ble_ans_c.c (see function cccd_configure() )
    Hope that helps.
    Carles
