nrf_log fixes in SDK14.1.0
I've noticed following line in SDK14.1 release notes:
  • Fixed a bug where nrf_log could crash when heavily loaded. `
I'm using SDK13.1 in my current project and I'm experiencing nrf_log related crashes under load as described here.
Please elaborate on what exactly was fixed and if it's related to problems I'm experiencing. Also if possible please provide some pointers on how to backport this fix into SDK13.1. Unfortunately I can't upgrade to SDK14.1 at this time.
  • There are number of issues with logging, even with SDK 14.2.0. The change in Krzysztof's answer goes a long way to fixing issues related to buffer overflow in normal operating conditions. This change fixes issues when using NRF_LOG_PUSH which could incorrectly return a pointer to non-contiguous memory and result in memory overwrites outside of the log buffer.
    I've attempted to address some additional issues with the nrf log front end including the following:
    • Add consistent handling of log buffer allocations by always setting the allocated log buffer type as INAVLID.
    • Ensuring that buffer full can be distinguished from buffer empty condition.
    • Better handling of errors when there is no log buffer space remaining.
    • Added notes which indicate additional design issues with the logging system which could be addressed in future.
    See the attached nrf_log_frontend.c. This file is based on SDK 14.2.0 and addresses some of the issues listed above. All '// NOTE:' comment lines indcate changes from SDK 14.2.0 with reasons for the change.
    Updated 22 Feb 2018: Fixed additional bug in nrf_log_frontend.c related to buffering of hex data and rewrote buffering used by nrf_log_push.  See new attachment
     * Copyright (c) 2016 - 2017, Nordic Semiconductor ASA
     * All rights reserved.
    #include "sdk_common.h"
    #if NRF_MODULE_ENABLED(NRF_LOG)
    #include "app_util.h"
    #include "nrf_log.h"
    #include "nrf_log_internal.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_section.h"
    #include "nrf_memobj.h"
    #include "nrf_atomic.h"
    #include <string.h>
    STATIC_ASSERT((NRF_LOG_BUFSIZE % 4) == 0);
    STATIC_ASSERT(IS_POWER_OF_TWO(NRF_LOG_BUFSIZE));
    #define NRF_LOG_BUF_WORDS (NRF_LOG_BUFSIZE/4)
    #if NRF_LOG_BUF_WORDS < 32
    #warning "NRF_LOG_BUFSIZE too small, significant number of logs may be lost."
    NRF_MEMOBJ_POOL_DEF(mempool, NRF_LOG_MSGPOOL_ELEMENT_SIZE, NRF_LOG_MSGPOOL_ELEMENT_COUNT);
    #define NRF_LOG_BACKENDS_FULL           0xFF
    #define NRF_LOG_FILTER_BITS_PER_BACKEND 3
    #define NRF_LOG_MAX_BACKENDS           (32/NRF_LOG_FILTER_BITS_PER_BACKEND)
    #define NRF_LOG_MAX_HEXDUMP            (NRF_LOG_MSGPOOL_ELEMENT_SIZE*NRF_LOG_MSGPOOL_ELEMENT_COUNT/2)
     * brief An internal control block of the logger
     * @note Circular buffer is using never cleared indexes and a mask. It means
     * that logger may break when indexes overflows. However, it is quite unlikely.
     * With rate of 1000 log entries with 2 parameters per second such situation
     * would happen after 12 days.
    typedef struct
        uint32_t                  wr_idx;          // Current write index (never reset)
        uint32_t                  rd_idx;          // Current read index  (never_reset)
        uint32_t                  mask;            // Size of buffer (must be power of 2) presented as mask
        uint32_t                  buffer[NRF_LOG_BUF_WORDS];
        nrf_log_timestamp_func_t  timestamp_func;  // A pointer to function that returns timestamp
        nrf_log_backend_t *       p_backend_head;
        nrf_atomic_flag_t         log_skipped;
        bool                      autoflush;
    } log_data_t;
    static log_data_t   m_log_data;
    static const char * m_overflow_info = "Overflow";
    /*lint -save -esym(526,log_const_data*) -esym(526,log_dynamic_data*)*/
    NRF_SECTION_DEF(log_dynamic_data, nrf_log_module_dynamic_data_t);
    NRF_SECTION_DEF(log_const_data, nrf_log_module_const_data_t);
    /*lint -restore*/
    NRF_LOG_MODULE_REGISTER();
    // Helper macros for section variables.
    #define NRF_LOG_DYNAMIC_SECTION_VARS_GET(i)          NRF_SECTION_ITEM_GET(log_dynamic_data, nrf_log_module_dynamic_data_t, (i))
    #define NRF_LOG_CONST_SECTION_VARS_GET(i)          NRF_SECTION_ITEM_GET(log_const_data, nrf_log_module_const_data_t, (i))
    #define NRF_LOG_CONST_SECTION_VARS_COUNT           NRF_SECTION_ITEM_COUNT(log_const_data, nrf_log_module_const_data_t)
    // NOTE: Reordered population of 'pushed' header so that the header type is always
    // the last item in a header set to indicate a non-invalid type.
    #define PUSHED_HEADER_FILL(P_HDR, OFFSET, LENGTH)                   \
        (P_HDR)->base.pushed.offset   = OFFSET;                         \
        (P_HDR)->base.pushed.len      = LENGTH;                         \
        (P_HDR)->base.pushed.type     = HEADER_TYPE_PUSHED;
    ret_code_t nrf_log_init(nrf_log_timestamp_func_t timestamp_func)
        if (NRF_LOG_USES_TIMESTAMP && (timestamp_func == NULL))
            return NRF_ERROR_INVALID_PARAM;
        m_log_data.mask         = NRF_LOG_BUF_WORDS - 1;
        m_log_data.wr_idx       = 0;
        m_log_data.rd_idx       = 0;
        m_log_data.log_skipped  = 0;
        m_log_data.autoflush    = NRF_LOG_DEFERRED ? false : true;
        if (NRF_LOG_USES_TIMESTAMP)
            m_log_data.timestamp_func = timestamp_func;
        ret_code_t err_code = nrf_memobj_pool_init(&mempool);
        if (err_code != NRF_SUCCESS)
            return err_code;
        uint32_t modules_cnt = NRF_LOG_CONST_SECTION_VARS_COUNT;
        uint32_t i;
        if (NRF_LOG_FILTERS_ENABLED)
            uint32_t j;
            //sort modules by name
            for (i = 0; i < modules_cnt; i++)
                uint32_t idx = 0;
                for (j = 0; j < modules_cnt; j++)
                    if  (i != j)
                        char const * p_name0 = NRF_LOG_CONST_SECTION_VARS_GET(i)->p_module_name;
                        char const * p_name1 = NRF_LOG_CONST_SECTION_VARS_GET(j)->p_module_name;
                        if (strncmp(p_name0, p_name1, 20) > 0)
                            idx++;
                nrf_log_module_dynamic_data_t * p_module_ddata = NRF_LOG_DYNAMIC_SECTION_VARS_GET(i);
                p_module_ddata->filter = 0;
                p_module_ddata->module_id = i;
                p_module_ddata->order_idx = idx;
            for(i = 0; i < modules_cnt; i++)
        return NRF_SUCCESS;
    uint32_t nrf_log_module_cnt_get(void)
        return NRF_LOG_CONST_SECTION_VARS_COUNT;
    static ret_code_t module_idx_get(uint32_t * p_idx, bool ordered_idx)
        if (ordered_idx)
            uint32_t module_cnt = nrf_log_module_cnt_get();
            uint32_t i;
            for (i = 0; i < module_cnt; i++)
                nrf_log_module_dynamic_data_t * p_module_data = NRF_LOG_DYNAMIC_SECTION_VARS_GET(i);
                if (p_module_data->order_idx == *p_idx)
                    *p_idx = i;
                    return NRF_SUCCESS;
            return NRF_ERROR_NOT_FOUND;
            return NRF_SUCCESS;
    const char * nrf_log_module_name_get(uint32_t module_id, bool ordered_idx)
        if (module_idx_get(&module_id, ordered_idx) == NRF_SUCCESS)
            nrf_log_module_const_data_t * p_module_data = NRF_LOG_CONST_SECTION_VARS_GET(module_id);
            return p_module_data->p_module_name;
            return NULL;
    uint8_t nrf_log_color_id_get(uint32_t module_id, nrf_log_severity_t severity)
        uint8_t color_id;
        switch (severity)
        case NRF_LOG_SEVERITY_ERROR:
            color_id = NRF_LOG_ERROR_COLOR;
        case NRF_LOG_SEVERITY_WARNING:
            color_id = NRF_LOG_WARNING_COLOR;
        case NRF_LOG_SEVERITY_INFO:
            color_id = p_module_data->info_color_id;
        case NRF_LOG_SEVERITY_DEBUG:
            color_id = p_module_data->debug_color_id;
            color_id = 0;
        return color_id;
    static uint32_t higher_lvl_get(uint32_t lvls)
        uint32_t top_lvl = 0;
        uint32_t tmp_lvl;
        uint32_t i;
        //Find highest level enabled by backends
        for (i = 0; i < (32/NRF_LOG_LEVEL_BITS); i+=NRF_LOG_LEVEL_BITS)
            tmp_lvl = BF_GET(lvls,NRF_LOG_LEVEL_BITS, i);
            if (tmp_lvl > top_lvl)
                top_lvl = tmp_lvl;
        return top_lvl;
    void nrf_log_module_filter_set(uint32_t backend_id, uint32_t module_id, nrf_log_severity_t severity)
            nrf_log_module_dynamic_data_t * p_module_filter = NRF_LOG_DYNAMIC_SECTION_VARS_GET(module_id);
            p_module_filter->filter_lvls &= ~(NRF_LOG_LEVEL_MASK << (NRF_LOG_LEVEL_BITS * backend_id));
            p_module_filter->filter_lvls |= (severity & NRF_LOG_LEVEL_MASK) << (NRF_LOG_LEVEL_BITS * backend_id);
            p_module_filter->filter = higher_lvl_get(p_module_filter->filter_lvls);
    nrf_log_severity_t nrf_log_module_filter_get(uint32_t backend_id,
                                                 uint32_t module_id,
                                                 bool ordered_idx,
                                                 bool dynamic)
        nrf_log_severity_t severity = NRF_LOG_SEVERITY_NONE;
        if (NRF_LOG_FILTERS_ENABLED && dynamic)
                severity = (nrf_log_severity_t)((p_module_filter->filter_lvls >> (NRF_LOG_LEVEL_BITS * backend_id)) &
        NRF_LOG_LEVEL_MASK);
        else if (!dynamic)
                severity = (nrf_log_severity_t)p_module_data->compiled_lvl;
        return severity;
     * @brief Skips the oldest, not pushed logs to make space for new logs.
     * @details This function moves forward read index to prepare space for new logs.
     *   Must be called within a critical section.
    static void log_skip(void)
        // NOTE: Removed log_skipping.  As log_skip is called inside a critical section, there
        // was no valid way that log_skip could be interrupted.  There was a race condition in
        // the use of log_skipping test at end of function, typical test-and-set type race between test
        // for skipping and set of rd_idx.
        (void)nrf_atomic_flag_set(&m_log_data.log_skipped);
        uint32_t           rd_idx = m_log_data.rd_idx;
        uint32_t           mask   = m_log_data.mask;
        nrf_log_header_t * p_header = (nrf_log_header_t *)&m_log_data.buffer[rd_idx & mask];
        nrf_log_header_t   header;
        // Skip any string that is pushed to the circular buffer.
        while (p_header->base.generic.type == HEADER_TYPE_PUSHED)
            rd_idx       += PUSHED_HEADER_SIZE;
            rd_idx       += (p_header->base.pushed.len + p_header->base.pushed.offset);
            // End of buffer check.  If last message in buffer is a PUSHED log, cannot free any
            // more space.
            if ((rd_idx + 1) == m_log_data.wr_idx)
                return;
        uint32_t i;
        for (i = 0; i < HEADER_SIZE; i++)
            ((uint32_t*)&header)[i] = m_log_data.buffer[rd_idx++ & mask];
        switch (header.base.generic.type)
            case HEADER_TYPE_HEXDUMP:
                rd_idx += CEIL_DIV(header.base.hexdump.len, sizeof(uint32_t));
            case HEADER_TYPE_STD:
                rd_idx += header.base.std.nargs;
                ASSERT(false);
        m_log_data.rd_idx = rd_idx;
    static inline void std_header_set(uint32_t severity_mid,
                                          char const * const p_str,
                                          uint32_t nargs,
                                          uint32_t wr_idx,
                                          uint32_t mask)
        //Prepare header - in reverse order to ensure that packet type is validated (set to STD as last action)
        uint16_t module_id = severity_mid >> NRF_LOG_MODULE_ID_POS;
        ASSERT(module_id < nrf_log_module_cnt_get());
        m_log_data.buffer[(wr_idx + 1) & mask] = module_id;
            m_log_data.buffer[(wr_idx + 2) & mask] = m_log_data.timestamp_func();
        nrf_log_header_t * p_header = (nrf_log_header_t *)&m_log_data.buffer[wr_idx & mask];
        p_header->base.std.raw      = (severity_mid & NRF_LOG_RAW) ? 1 : 0;
        p_header->base.std.severity = severity_mid & NRF_LOG_LEVEL_MASK;
        p_header->base.std.nargs    = nargs;
        p_header->base.std.addr     = ((uint32_t)(p_str) & STD_ADDR_MASK);
        p_header->base.std.type     = HEADER_TYPE_STD;
     * @brief Determine number of words available for storage of log data.
     * @return Number of words available
    // NOTE: Seperated calc_available_words to its own function to avoid duplicating logic.
    // Modified to report maximum of (buf-len-1) available words to support distinguishing
    // between empty and full buffer conditions.
    static inline uint32_t calc_available_words()
        // wr_idx == rx_idx is buffer empty condition.  wr_idx+1 == rd_idx is buffer full condition.
        // As a result, use (buffer size - 1) as maximum possible availability when determining how
        // many free words are available.  Relies on mask being (buffer size - 1)
        return m_log_data.mask - (m_log_data.wr_idx - m_log_data.rd_idx);
     * @brief Allocates chunk in a buffer for one entry and injects overflow if
     * there is no room for requested entry.
     * @param content_len   Number of 32bit arguments. In case of allocating for hex dump it
     *                      is the size of the buffer in 32bit words (ceiled).
     * @param p_wr_idx      Pointer to write index.
     * @return True if successful allocation, false otherwise.
    static inline bool buf_prealloc(uint32_t content_len, uint32_t * p_wr_idx)
        uint32_t req_len = content_len + HEADER_SIZE;
        bool     ret            = true;
        CRITICAL_REGION_ENTER();
        // NOTE: Removed use of ovflw_tag_size.  Seems as though original code was allocating
        // space for original header + overflow header and I didn't understand why this was
        // required.  If an overflow occurs, a separate check is made below to determine if there
        // is space to inject a 'buffer overflowed' type header.
        *p_wr_idx = m_log_data.wr_idx;
        uint32_t available_words = calc_available_words();
        uint32_t required_words  = req_len;
        // NOTE: Introduced a flag to ensure log_skip() can occur at most 1 time in while() loop.
        // If enough space can't be made free after initial log_skip(), then there's no chance
        // that calling it again will free more space as this function is called inside a
        // critical section.  The best that can be done after a log_skip() if there is still
        // not enough space for the allocation is to revert to inject an 'overflow' message.
        bool allow_overflow = NRF_LOG_ALLOW_OVERFLOW;
        while (required_words > available_words)
            if (allow_overflow)
                log_skip();
                // Allow log_skip at most once to free space.  As this function operates in a critical
                // section, a context switch never occurs to enable more entries to be dequeued by
                // a different context.
                allow_overflow = false;
                if (available_words >= HEADER_SIZE)
                    // Overflow entry is injected
                    std_header_set(NRF_LOG_LEVEL_WARNING, m_overflow_info, 0, m_log_data.wr_idx, m_log_data.mask);
                    req_len = HEADER_SIZE;
                    // No more room for any logs.
                    req_len = 0;
                ret = false;
        // NOTE: Only mark the header as invalid if an allocation occurred.  Previously, if not
        // enough space was made available then it was possible to write this header data into
        // the buffer.  Writing into unallocated buffer area should be discouraged.
        if (ret) {
            // Mark header as invalid.
            nrf_log_generic_header_t * p_header = (nrf_log_generic_header_t *)&m_log_data.buffer[m_log_data.wr_idx & m_log_data.mask];
            p_header->type = HEADER_TYPE_INVALID;
        m_log_data.wr_idx += req_len;
        CRITICAL_REGION_EXIT();
        return ret;
     * @brief Function for preallocating a continuous chunk of memory from circular buffer.
     * If buffer does not fit starting from current position it will be allocated at
     * the beginning of the circular buffer and offset will be returned indicating
     * how much memory has been ommited at the end of the buffer. Function is
     * using critical section.
     * @param len32    Length of buffer to allocate. Given in words.
     * @param p_offset Offset of the buffer.
     * @return A pointer to the allocated buffer. NULL if allocation failed.
    static inline uint32_t * cont_buf_prealloc(uint32_t len32,
                                               uint32_t * p_offset,
        // NOTE: Substantially reworked buffer length calculations with care given to ensure that
        // correct offset and indices are used when buffer wraparound occurs.  It is no longer required
        // that (header+pushed data) has to be contiguous.
        // Added a temporary to store the amount of buffer space consumed as part of the alloc, and
        // only update the wr_idx if the allocation succeeded.
        uint32_t * p_buf = NULL;
        uint32_t offset = 0;
        uint32_t wr_idx = m_log_data.wr_idx;
        if (available_words >= PUSHED_HEADER_SIZE)
            wr_idx += PUSHED_HEADER_SIZE;
            available_words -= PUSHED_HEADER_SIZE;
            // Determine number of words available after wr_idx to either end of log buffer buffer or
            // until first fifo entry at rd_idx.
            uint32_t cont_words = mask + 1 - (wr_idx & mask);
            if (cont_words > available_words) {
                cont_words = available_words;
            if (len32 <= cont_words) {
                // buffer will fit as is with no offset
                p_buf              = &m_log_data.buffer[wr_idx & mask];
                wr_idx             += len32;
            else {
                // skip over words to advance to start of buffer to look for next contiguous block.
                available_words -= cont_words;
                if (len32 <= available_words) {
                    // wrapping to the begining of the buffer
                    wr_idx          += cont_words + len32;
                    offset          = cont_words;
                    p_buf           = &m_log_data.buffer[0];
        // NOTE: It is possible that the allocation did not succeed so only write the header data
        // and increment wr_idx on success to avoid writing into unallocated buffer space.
        // To be consistent with other allocators, set the header type to invalid on allocation
        // as an indicator that buffer has not yet been filled with valid data.
        if (p_buf != NULL)
            nrf_log_generic_header_t * p_header = (nrf_log_generic_header_t *)&m_log_data.buffer[m_log_data.wr_idx & mask];
            m_log_data.wr_idx = wr_idx;
            *p_offset = offset;
        return p_buf;
    uint32_t nrf_log_push(char * const p_str)
        if ((m_log_data.autoflush) || (p_str == NULL))
            return (uint32_t)p_str;
        uint32_t slen      = strlen(p_str) + 1;
        uint32_t buflen    = CEIL_DIV(slen, sizeof(uint32_t));
        uint32_t wr_idx;
        char   * p_dst_str = (char *)cont_buf_prealloc(buflen, &offset, &wr_idx);
        if (p_dst_str)
            // NOTE: Swapped order of string copy and header fill to ensure that the header.type
            // is the last item to be set to indicate a valid log record.
            memcpy(p_dst_str, p_str, slen);
            PUSHED_HEADER_FILL(p_header, offset, buflen);
        else {
            // NOTE: Added support for a push failure due to buffer allocation fail.  In the
            // call NRF_LOG_INFO("a %s", NRF_LOG_PUSH("foo")) it is possible when logging from
            // multiple contexts that NRF_LOG_PUSH() may fail, but NRF_LOG_INFO will pass.  eg
            // FreeRTOS pulling items from queue allowing NRF_LOG_INFO to succeed if context
            // switch occurs between PUSH and LOG.  This means that a null pointer returned
            // from nrf_log_push could potentially result in null pointer defererence if the
            // NRF_LOG_INFO succeeds.  Modified to always return a valid pointer.  On overflow,
            // return pointer to the static buffer containing 'overflow' text.
            // No contiguous memory for string.  Avoid returning NULL which could result in null
            // pointer dereference if NRF_LOG call associated with the push succeeds.
            p_dst_str = (char*)m_overflow_info;
        return (uint32_t)p_dst_str;
    static inline void std_n(uint32_t severity_mid, char const * const p_str, uint32_t const * args, uint32_t nargs)
        uint32_t wr_idx;
        if (buf_prealloc(nargs, &wr_idx))
            // Proceed only if buffer was successfully preallocated.
            uint32_t data_idx = wr_idx + HEADER_SIZE;
            uint32_t i;
            for (i = 0; i < nargs; i++)
                m_log_data.buffer[data_idx++ & mask] = args[i];
            std_header_set(severity_mid, p_str, nargs, wr_idx, mask);
        if (m_log_data.autoflush)
            NRF_LOG_FLUSH();
    void nrf_log_frontend_std_0(uint32_t severity_mid, char const * const p_str)
        std_n(severity_mid, p_str, NULL, 0);
    void nrf_log_frontend_std_1(uint32_t            severity_mid,
                                uint32_t           val0)
        uint32_t args[] = {val0};
        std_n(severity_mid, p_str, args,  ARRAY_SIZE(args));
    void nrf_log_frontend_std_2(uint32_t           severity_mid,
                                uint32_t           val0,
                                uint32_t           val1)
        uint32_t args[] = {val0, val1};
    void nrf_log_frontend_std_3(uint32_t           severity_mid,
                                uint32_t           val0,
                                uint32_t           val1,
                                uint32_t           val2)
        uint32_t args[] = {val0, val1, val2};
    void nrf_log_frontend_std_4(uint32_t           severity_mid,
                                uint32_t           val0,
                                uint32_t           val1,
                                uint32_t           val2,
                                uint32_t           val3)
        uint32_t args[] = {val0, val1, val2, val3};
    void nrf_log_frontend_std_5(uint32_t           severity_mid,
                                uint32_t           val0,
                                uint32_t           val1,
                                uint32_t           val2,
                                uint32_t           val3,
                                uint32_t           val4)
        uint32_t args[] = {val0, val1, val2, val3, val4};
    void nrf_log_frontend_std_6(uint32_t           severity_mid,
                                uint32_t           val0,
                                uint32_t           val1,
                                uint32_t           val2,
                                uint32_t           val3,
                                uint32_t           val4,
                                uint32_t           val5)
        uint32_t args[] = {val0, val1, val2, val3, val4, val5};
    void nrf_log_frontend_hexdump(uint32_t           severity_mid,
                                  const void * const p_data,
                                  uint16_t           length)
        uint32_t wr_idx;
        if (buf_prealloc(CEIL_DIV(length, sizeof(uint32_t)), &wr_idx))
            uint32_t header_wr_idx = wr_idx;
            wr_idx += HEADER_SIZE;
            uint32_t space0 = sizeof(uint32_t) * (mask + 1 - (wr_idx & mask));
            if (length <= space0)
                memcpy(&m_log_data.buffer[wr_idx & mask], p_data, length);
                memcpy(&m_log_data.buffer[wr_idx & mask], p_data, space0);
                // NOTE: length variable cannot be modified as this is used below when filling out the
                // length of this record in log header.
                memcpy(&m_log_data.buffer[0], &((uint8_t *)p_data)[space0], length - space0);
            //Prepare header - in reverse order to ensure that packet type is validated (set to HEXDUMP as last action)
               m_log_data.buffer[(header_wr_idx + 2) & mask] = m_log_data.timestamp_func();
            m_log_data.buffer[(header_wr_idx + 1) & mask] = severity_mid >> NRF_LOG_MODULE_ID_POS;
            //Header prepare
            nrf_log_header_t * p_header = (nrf_log_header_t *)&m_log_data.buffer[header_wr_idx & mask];
            p_header->base.hexdump.raw      = (severity_mid & NRF_LOG_RAW) ? 1 : 0;
            p_header->base.hexdump.severity = severity_mid & NRF_LOG_LEVEL_MASK;
            p_header->base.hexdump.offset   = 0;
            p_header->base.hexdump.len      = length;
            p_header->base.hexdump.type     = HEADER_TYPE_HEXDUMP;
            NRF_LOG_FLUSH();
    bool buffer_is_empty(void)
        return (m_log_data.rd_idx == m_log_data.wr_idx);
    // NOTE:  Unresolved issue. Dequing a message also discards prior PUSHED headers.  There is a
    // potential race with this behaviour when logging from multiple contexts, eg. Both from task and
    // ISR contexts.  Consider the following bits of code operating in two contexts:
    // Context A (eg task):
    // NRF_LOG_INFO("a %s", NRF_LOG_PUSH("a"));
    //                     ^ Context switch here
    // Context B (eg ISR):
    // NRF_LOG_INFO("b %s", NRF_LOG_PUSH("b"));
    // If context switch A->B occurs after NRF_LOG_PUSH("a") but before NRF_LOG_INFO("a %s"), "a" and
    // "b" are pushed, followed by STD header for Context B, then STD header for Context A.
    // The log queue looks like this:  PUSHED("a"), PUSHED("b"), STD("b %s"), STD("a %s").
    // When logs are processed by nrf_log_frontend_deque(), STD("b %s") will be processed, then
    // PUSHED("a") and PUSHED("b") discarded by moving the rd_idx to STD("a %s").  This leaves
    // STD("a %s") in the queue with a dangling pointer to already-discarded PUSHED("a").  It is likely
    // that PUSHED("a") will still exist in the queue at the correct location when STD("a %s") is
    // processed but there is no guarantee and a potential for STD("a %s") to reference invalid memory.
    // If log buffer is not tiny and logs are flushed regularly this bug will likely not occur.
    // Short of doing both NRF_LOG_XXX and NRF_LOG_PUSH in a critical section, can't think of an easy
    // workaround.
    // NOTE: Unresolved issue. A rare race on rd_idx may occur in this function in the event of
    // log_skip() being invoked during dequeue (possibly from ISR) and new log data being so large as
    // to overwrite the record currently being dequeued.  Again, unlikely to occur in systems with large
    // log buffer.  ie.  The record at rd_idx being processed by dequeue could be overwritten by
    // nrf log.
    // NOTE: Improvement suggestion.  The time in critical sections could be large and affect the worst case
    // latency for high priority interrupts.  For nrf52 with Cortex-M4 core, it would be preferable to
    // use lockless sections using LDREX/STREX on the wr_idx instead of CRITICAL_SECTION_XXX. eg.
    // do {
    //    ldrex(wr_idx);
    //    new_wr_idx = buffer allocate
    // } while (strex(new_wr_idx))
    // Using this approach would allow interrupts to remain enabled during logging with the downside
    // that setting the header type to invalid would not be atomic with updating wr_idx.
    bool nrf_log_frontend_dequeue(void)
        if (buffer_is_empty())
            return false;
        //It has to be ensured that reading rd_idx occurs after skipped flag is cleared.
        __DSB();
        nrf_memobj_t *     p_msg_buf = NULL;
        uint32_t           memobj_offset = 0;
        uint32_t           severity = 0;
        uint32_t i;
        if (header.base.generic.type == HEADER_TYPE_HEXDUMP)
            uint32_t orig_data_len  = header.base.hexdump.len;
            uint32_t data_len       = MIN(header.base.hexdump.len, NRF_LOG_MAX_HEXDUMP); //limit the data
            header.base.hexdump.len = data_len;
            uint32_t msg_buf_size8  = sizeof(uint32_t)*HEADER_SIZE + data_len;
            severity = header.base.hexdump.severity;
            p_msg_buf = nrf_memobj_alloc(&mempool, msg_buf_size8);
            if (p_msg_buf)
                nrf_memobj_get(p_msg_buf);
                nrf_memobj_write(p_msg_buf, &header, HEADER_SIZE*sizeof(uint32_t), memobj_offset);
                memobj_offset += HEADER_SIZE*sizeof(uint32_t);
                uint32_t space0 = sizeof(uint32_t) * (mask + 1 - (rd_idx & mask));
                // NOTE: Reworked index logic by removing checks for space0 == 0.  space0 will always
                // be > 0 since (mask + 1) is always greater than (number & mask)
                if (data_len > space0)
                    uint8_t * ptr0 = (uint8_t *)&m_log_data.buffer[rd_idx & mask];
                    uint8_t   len0 = space0;
                    uint8_t * ptr1 = (uint8_t *)&m_log_data.buffer[0];
                    uint8_t   len1 = data_len - space0;
                    nrf_memobj_write(p_msg_buf, ptr0, len0, memobj_offset);
                    memobj_offset += len0;
                    if (len1)
                        nrf_memobj_write(p_msg_buf, ptr1, len1, memobj_offset);
                    uint8_t * p_data = (uint8_t *)&m_log_data.buffer[rd_idx & mask];
                    nrf_memobj_write(p_msg_buf, p_data, data_len, memobj_offset);
                rd_idx += CEIL_DIV(orig_data_len, sizeof(uint32_t));
        else if (header.base.generic.type == HEADER_TYPE_STD) // standard entry
            header.base.std.nargs = MIN(header.base.std.nargs, NRF_LOG_MAX_NUM_OF_ARGS);
            uint32_t msg_buf_size32 = HEADER_SIZE + header.base.std.nargs;
            severity = header.base.std.severity;
            p_msg_buf = nrf_memobj_alloc(&mempool, msg_buf_size32*sizeof(uint32_t));
            if (p_msg_buf)
                for (i = 0; i < header.base.std.nargs; i++)
                    nrf_memobj_write(p_msg_buf, &m_log_data.buffer[rd_idx++ & mask],
                    memobj_offset += sizeof(uint32_t);
        else if (header.base.generic.type == HEADER_TYPE_INVALID && (m_log_data.log_skipped == 0))
            //invalid type can only occur if log entry was interrupted by log_process. It is likly final flush
            // and finding invalid type means that last entry in the buffer was reached (the one that was interrupted).
            // Stop processing immediately.
            return false;
            //Do nothing. In case of log overflow buffer can contain corrupted data.
        if (p_msg_buf)
            nrf_log_backend_t * p_backend = m_log_data.p_backend_head;
            if (NRF_LOG_ALLOW_OVERFLOW && m_log_data.log_skipped)
                // Check if any log was skipped during log processing. Do not forward log if skipping
                // occured because data may be invalid.
                nrf_memobj_put(p_msg_buf);
                while (p_backend)
                    bool entry_accepted = false;
                    if (nrf_log_backend_is_enabled(p_backend) == true)
                            uint8_t backend_id = nrf_log_backend_id_get(p_backend);
                            uint32_t filter_lvls = NRF_LOG_DYNAMIC_SECTION_VARS_GET(header.module_id)->filter_lvls;
                            uint32_t backend_lvl = (filter_lvls >> (backend_id*NRF_LOG_LEVEL_BITS))
                            if (backend_lvl >= severity)
                                entry_accepted = true;
                            (void)severity;
                    if (entry_accepted)
                     nrf_log_backend_put(p_backend, p_msg_buf);
                    p_backend = p_backend->p_next;
                if (NRF_LOG_ALLOW_OVERFLOW)
                    // Read index can be moved forward only if dequeueing process was not interrupt by
                    // skipping procedure. If NRF_LOG_ALLOW_OVERFLOW is set then in case of buffer gets full
                    // and new logger entry occurs, oldest entry is removed. In that case read index is
                    // changed and updating it here would corrupt the internal circular buffer.
                    if (m_log_data.log_skipped == 0)
        return buffer_is_empty() ? false : true;
    static int32_t backend_id_assign(void)
        int32_t candidate_id;
        nrf_log_backend_t * p_backend;
        bool id_available;
        for (candidate_id = 0; candidate_id < NRF_LOG_MAX_BACKENDS; candidate_id++)
            id_available = true;
            while (p_backend)
                if (nrf_log_backend_id_get(p_backend) == candidate_id)
                    id_available = false;
            if (id_available)
                return candidate_id;
        return -1;
    int32_t nrf_log_backend_add(nrf_log_backend_t * p_backend, nrf_log_severity_t severity)
        int32_t id = backend_id_assign();
        if (id == -1)
            return id;
        nrf_log_backend_id_set(p_backend, id);
        //add to list
        if (m_log_data.p_backend_head == NULL)
           m_log_data.p_backend_head   = p_backend;
           p_backend->p_next = NULL;
            p_backend->p_next = m_log_data.p_backend_head->p_next;
            m_log_data.p_backend_head->p_next = p_backend;
            uint32_t i;
            for (i = 0; i < nrf_log_module_cnt_get(); i++)
                nrf_log_severity_t buildin_lvl = nrf_log_module_filter_get(id, i, false, false);
                nrf_log_severity_t actual_severity = MIN(buildin_lvl, severity);
                nrf_log_module_filter_set(nrf_log_backend_id_get(p_backend), i, actual_severity);
        return id;
    void nrf_log_backend_remove(nrf_log_backend_t * p_backend)
        nrf_log_backend_t * p_curr = m_log_data.p_backend_head;
        nrf_log_backend_t * p_prev = NULL;
        while (p_curr != p_backend)
            p_prev = p_curr;
            p_curr = p_curr->p_next;
        if (p_prev)
            p_prev->p_next = p_backend->p_next;
            m_log_data.p_backend_head = NULL;
    void nrf_log_panic(void)
        m_log_data.autoflush = true;
        while (p_backend)
            nrf_log_backend_enable(p_backend);
            nrf_log_backend_panic_set(p_backend);
    #if NRF_LOG_CLI_CMDS
    #include "nrf_cli.h"
    static const char * m_severity_lvls[] = {
            "none",
            "error",
            "warning",
            "info",
            "debug",
    static const char * m_severity_lvls_sorted[] = {
            "debug",
            "error",
            "info",
            "none",
            "warning",
    static void log_status(nrf_cli_t const * p_cli, size_t argc, char **argv)
        uint32_t modules_cnt = nrf_log_module_cnt_get();
        uint32_t backend_id = p_cli->p_log_backend->backend.id;
        uint32_t i;
        if (!nrf_log_backend_is_enabled(&p_cli->p_log_backend->backend))
            nrf_cli_fprintf(p_cli, NRF_CLI_ERROR, "Logs are halted!\r\n");
        nrf_cli_fprintf(p_cli, NRF_CLI_NORMAL, "%-24s | current | buildin \r\n", "module_name");
        nrf_cli_fprintf(p_cli, NRF_CLI_NORMAL, "------------------------------------------\r\n");
            nrf_log_severity_t module_dynamic_lvl = nrf_log_module_filter_get(backend_id, i, true, true);
            nrf_log_severity_t module_compiled_lvl = nrf_log_module_filter_get(backend_id, i, true, false);
            nrf_log_severity_t actual_compiled_lvl = MIN(module_compiled_lvl, (nrf_log_severity_t)NRF_LOG_DEFAULT_LEVEL);
            nrf_cli_fprintf(p_cli, NRF_CLI_NORMAL, "%-24s | %-7s | %s%s\r\n",
                                      nrf_log_module_name_get(i, true),
                                      m_severity_lvls[module_dynamic_lvl],
                                      m_severity_lvls[actual_compiled_lvl],
                                      actual_compiled_lvl < module_compiled_lvl ? "*" : "");
    static bool module_id_get(const char * p_name, uint32_t * p_id)
        const char * p_tmp_name;
        uint32_t j;
            p_tmp_name = nrf_log_module_name_get(j, false);
            if (strncmp(p_tmp_name, p_name, 32) == 0)
                *p_id = j;
        return (j != modules_cnt);
    static bool module_id_filter_set(uint32_t backend_id,
                                     uint32_t module_id,
                                     nrf_log_severity_t lvl)
        nrf_log_severity_t buildin_lvl = nrf_log_module_filter_get(backend_id, module_id, false, false);
        if (lvl > buildin_lvl)
            return false;
            nrf_log_module_filter_set(backend_id, module_id, lvl);
            return true;
    static void log_ctrl(nrf_cli_t const * p_cli, size_t argc, char **argv)
        nrf_log_severity_t lvl;
        uint32_t first_m_name_idx;
        uint32_t i;
        bool all_modules = false;
        if (argc >  0)
            if (strncmp(argv[0], "enable", 7) == 0)
                if (argc == 1)
                    nrf_cli_fprintf(p_cli, NRF_CLI_ERROR, "Bad parameter count.\r\n");
                    return;
                if (argc == 2)
                    all_modules = true;
                for (i = 0; i < ARRAY_SIZE(m_severity_lvls); i++)
                    if (strncmp(argv[1], m_severity_lvls[i], 10) == 0)
                if (i == ARRAY_SIZE(m_severity_lvls))
                    nrf_cli_fprintf(p_cli, NRF_CLI_ERROR, "Unknown severity level: %s\r\n", argv[1]);
                    return;
                lvl = (nrf_log_severity_t)i;
                first_m_name_idx = 2;
            else if (strncmp(argv[0], "disable", 8) == 0)
                if (argc == 1)
                    all_modules = true;
                lvl = NRF_LOG_SEVERITY_NONE;
                first_m_name_idx = 1;
                nrf_cli_fprintf(p_cli, NRF_CLI_ERROR, "Unknown option: %s\r\n", argv[0]);
                return;
            if (all_modules)
                    if (module_id_filter_set(backend_id, i, lvl) == false)
                        nrf_cli_fprintf(p_cli, NRF_CLI_ERROR, "Level unavailable for module: %s\r\n", nrf_log_module_name_get(i, false));
                for (i = first_m_name_idx; i < argc; i++)
                    uint32_t module_id = 0;
                    if (module_id_get(argv[i], &module_id) == false)
                        nrf_cli_fprintf(p_cli, NRF_CLI_ERROR, "Unknown module:%s\r\n", argv[i]);
                    if (module_id_filter_set(backend_id, module_id, lvl) == false)
                        nrf_cli_fprintf(p_cli, NRF_CLI_ERROR, "Level unavailable for module: %s\r\n", nrf_log_module_name_get(module_id, false));
    static void module_name_get(size_t idx, nrf_cli_static_entry_t * p_static);
    NRF_CLI_CREATE_DYNAMIC_CMD(m_module_name, module_name_get);
        p_static->handler = NULL;
        p_static->p_help  = NULL;
        p_static->p_subcmd = &m_module_name;
        p_static->p_syntax = nrf_log_module_name_get(idx, true);
    static void severity_lvl_get(size_t idx, nrf_cli_static_entry_t * p_static)
        p_static->p_syntax = (idx < ARRAY_SIZE(m_severity_lvls_sorted)) ?
                                                        m_severity_lvls_sorted[idx] : NULL;
    NRF_CLI_CREATE_DYNAMIC_CMD(m_severity_lvl, severity_lvl_get);
    static void log_halt(nrf_cli_t const * p_cli, size_t argc, char **argv)
        nrf_log_backend_disable(&p_cli->p_log_backend->backend);
    static void log_go(nrf_cli_t const * p_cli, size_t argc, char **argv)
        nrf_log_backend_enable(&p_cli->p_log_backend->backend);
    NRF_CLI_CREATE_STATIC_SUBCMD_SET(m_sub_log_stat)
        NRF_CLI_CMD(disable, &m_module_name,
            "'log disable <module_0> .. <module_n>' disables logs in specified "
            "modules (all if no modules specified).",
            log_ctrl),
        NRF_CLI_CMD(enable, &m_severity_lvl,
            "'log enable <level> <module_0> ...  <module_n>' enables logs up to given level in "
            "specified modules (all if no modules specified).",
            log_ctrl),
        NRF_CLI_CMD(go, NULL, "Resume logging", log_go),
        NRF_CLI_CMD(halt, NULL, "Halt logging", log_halt),
        NRF_CLI_CMD(status, NULL, "Logger status", log_status),
        NRF_CLI_SUBCMD_SET_END
    static void log_cmd(nrf_cli_t const * p_cli, size_t argc, char **argv)
        if ((argc == 1) || nrf_cli_help_requested(p_cli))
            nrf_cli_help_print(p_cli, NULL, 0);
            return;
        nrf_cli_fprintf(p_cli, NRF_CLI_ERROR, "%s:%s%s\r\n", argv[0], " unknown parameter: ", argv[1]);
    NRF_CLI_CMD_REGISTER(log, &m_sub_log_stat, "Commands for controlling logger", log_cmd);
    #endif //NRF_LOG_CLI_CMDS
    #endif // NRF_MODULE_ENABLED(NRF_LOG)
  • @Krzsztof after a period of testing I can confirm that problem is resolved. Thanks for providing the patches!
  • @Nordic: Are bugs like this being tracked against SDK releases somewhere that we can see?
    It would be reassuring to see an triaged list of known bugs and each releases' ongoing support status. This would avoid peeps spending time re-discovering known bugs and enable them to judge whether to patch, wait for a fix or just avoid. This particular bug was not a great introduction to NRF52 as the symptoms varied with the text I was logging! This module is clearly labelled as experimental, so having bugs is no shame at all, but I would still give the fix a reasonably high priority because I think it quite likely to bite and discourage other peeps evaluating your products.
