Bonding Problem
Hello
I am trying to create secure connection between peripheral device and mobile app & central device.
I created my own custom service and want to make them secure.
But i am getting
app: ERROR 2 [NRF_ERROR_SOFTDEVICE_NOT_ENABLED] at ......\main.c:525
and this line is in this function:
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    ret_code_t err_code;
    switch (p_evt->evt_id)
        case PM_EVT_BONDED_PEER_CONNECTED:
            NRF_LOG_INFO("Connected to a previously bonded device.");
            // Start Security Request timer.
            err_code = app_timer_start(m_sec_req_timer_id, SECURITY_REQUEST_DELAY, NULL);
        } break;
        case PM_EVT_CONN_SEC_SUCCEEDED:
            pm_conn_sec_status_t conn_sec_status;
            // Check if the link is authenticated (meaning at least MITM).
            err_code = pm_conn_sec_status_get(p_evt->conn_handle, &conn_sec_status);
            if (conn_sec_status.mitm_protected)
                NRF_LOG_INFO("Link secured. Role: %d. conn_handle: %d, Procedure: %d",
                             ble_conn_state_role(p_evt->conn_handle),
                             p_evt->conn_handle,
                             p_evt->params.conn_sec_succeeded.procedure);
                // The peer did not use MITM, disconnect.
                NRF_LOG_INFO("Collector did not use MITM, disconnecting");
                err_code = pm_peer_id_get(m_conn_handle, &m_peer_to_be_deleted);
                err_code = sd_ble_gap_disconnect(m_conn_handle,
        } break;
        case PM_EVT_CONN_SEC_FAILED:
            NRF_LOG_INFO("Failed to secure connection. Disconnecting.");
        } break;
        case PM_EVT_CONN_SEC_CONFIG_REQ:
            // Reject pairing request from an already bonded peer.
            pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false};
            pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
        } break;
        case PM_EVT_STORAGE_FULL:
            // Run garbage collection on the flash.
            err_code = fds_gc();
            if (err_code == FDS_ERR_BUSY || err_code == FDS_ERR_NO_SPACE_IN_QUEUES)
                // Retry.
        } break;
            NRF_LOG_DEBUG("PM_EVT_PEERS_DELETE_SUCCEEDED [ advertising_start ]");
            advertising_start(/*false*/);
        } break;
        case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED:
            // The local database has likely changed, send service changed indications.
            pm_local_database_has_changed();
        } break;
        case PM_EVT_PEER_DATA_UPDATE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error);
        } break;
        case PM_EVT_PEER_DELETE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error);
        } break;
        case PM_EVT_PEERS_DELETE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error);
        } break;
        case PM_EVT_ERROR_UNEXPECTED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.error_unexpected.error);
        } break;
        case PM_EVT_CONN_SEC_START:
        case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
        case PM_EVT_PEER_DELETE_SUCCEEDED:
        case PM_EVT_LOCAL_DB_CACHE_APPLIED:
        case PM_EVT_SERVICE_CHANGED_IND_SENT:
        case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED:
and event is: PM_EVT_PEER_DATA_UPDATE_FAILED
How can fix this issue and what am i missing?
I am using nRF52832 and SD132
Here is my project file. ble_app_blinky.7z
