Two ways to send two or more bytes with nrf_drv_twi_tx
Hi! I use ICM-20602 motion sensor that is similar to MPU6050. Its communication type is also I2C.
I made I2C wrapping module for ICM-20602. In the module, I added i2c_write_byte and i2c_write_bytes functions like following code.
ret_code_t i2c_write_byte(uint8_t dev_addr, uint8_t reg_addr, uint8_t data)
    ret_code_t err_code;
    uint8_t tx_data[2] = { reg_addr, data };
    return nrf_drv_twi_tx(&m_twi_master, dev_addr, tx_data, 2, false);
But i2c_write_byte was not like this code. i2c_write_byte was like following code.
    err_code = nrf_drv_twi_tx(&m_twi_master, dev_addr, &reg_addr, 1, true);
    if (err_code != NRF_SUCCESS) return err_code;
    err_code = nrf_drv_twi_tx(&m_twi_master, dev_addr, &data, 1, false);
    return err_code;
But this old i2c_write_byte function did not work well. I think that operations of these i2c_write_byte functions must be an exact match. I read and read again API documents. But results of these i2c_write_byte functions are different. I don't know why. Please explain why results of these i2c_write_byte functions are different.
  • @martinbl Here it is! Please ignore macro function.
    ret_code_t i2c_init(){
    #if NEOSARCHIZO_DEBUG == 1
        NRF_LOG_INFO("i2c_init : start");
        const nrf_drv_twi_config_t config =
           .scl                = I2C_SCL_M,
           .sda                = I2C_SDA_M,
           .frequency          = NRF_TWI_FREQ_400K,
           .interrupt_priority = APP_IRQ_PRIORITY_LOW,
           .clear_bus_init     = false
        NRF_LOG_INFO("i2c_init : nrf_drv_twi_init");
        err_code = nrf_drv_twi_init(&m_twi_master, &config, NULL, NULL);
        NRF_LOG_INFO("i2c_init : nrf_drv_twi_enable");
        nrf_drv_twi_enable(&m_twi_master);
        NRF_LOG_INFO("i2c_init : end");
        return err_code;
  • Thanks. I figured that maybe you were using the driver in non-blocking mode with an event handler. Then it wouldn't work to call two tx functions right after one another like you do in i2c_write_byte(). But obviously you use your code in blocking mode so that can't be the problem. Please get back to us when you have tested with a logic analyzer then.
