Larger MTU results in HardFault
I'm running SDK 14.2 using FreeRTOS on a nrf52832.
When I increase NRF_SDH_BLE_GATT_MAX_MTU_SIZE to 158, the system ends up in Hard Fault.
Anyone have suggestions on where to being looking for the fault? The soft device has more than enough RAM, its actually telling me I can decrease it. I updated NRF_SDH_BLE_GAP_EVENT_LENGTH to 10, with no affect.
Any help is appreciated
  • Here are my source files for reference. Based on the ble_apphrs_freertos.  The only change I really made was trying to add MTU and DL
     * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    // Board/nrf6310/ble/ble_app_hrs_rtx/main.c
     * @brief Heart Rate Service Sample Application with RTX main file.
     * This file contains the source code for a sample application using RTX and the
     * Heart Rate service (and also Battery and Device Information services).
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "app_error.h"
    #include "ble.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_bas.h"
    #include "ble_hrs.h"
    #include "ble_dis.h"
    #include "ble_conn_params.h"
    #include "sensorsim.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_sdh_freertos.h"
    #include "app_timer.h"
    #include "peer_manager.h"
    #include "peer_manager_handler.h"
    #include "bsp_btn_ble.h"
    #include "FreeRTOS.h"
    #include "task.h"
    #include "timers.h"
    #include "semphr.h"
    #include "fds.h"
    #include "ble_conn_state.h"
    #include "nrf_drv_clock.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define DEVICE_NAME                         "Nordic_HRM_freeRTOS"                   /**< Name of device. Will be included in the advertising data. */
    #define MANUFACTURER_NAME                   "NordicSemiconductor"                   /**< Manufacturer. Will be passed to Device Information Service. */
    #define APP_BLE_OBSERVER_PRIO               3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG                1                                       /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_ADV_FAST_INTERVAL               64                                      /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_FAST_DURATION               1000                                    /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define APP_ADV_SLOW_INTERVAL               1600                                    /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_SLOW_DURATION               0                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define BATTERY_LEVEL_MEAS_INTERVAL         2000                                    /**< Battery level measurement interval (ms). */
    #define MIN_BATTERY_LEVEL                   81                                      /**< Minimum simulated battery level. */
    #define MAX_BATTERY_LEVEL                   100                                     /**< Maximum simulated battery level. */
    #define BATTERY_LEVEL_INCREMENT             1                                       /**< Increment between each simulated battery level measurement. */
    #define HEART_RATE_MEAS_INTERVAL            1000                                    /**< Heart rate measurement interval (ms). */
    #define MIN_HEART_RATE                      140                                     /**< Minimum heart rate as returned by the simulated measurement function. */
    #define MAX_HEART_RATE                      300                                     /**< Maximum heart rate as returned by the simulated measurement function. */
    #define HEART_RATE_INCREMENT                10                                      /**< Value by which the heart rate is incremented/decremented for each call to the simulated measurement function. */
    #define RR_INTERVAL_INTERVAL                300                                     /**< RR interval interval (ms). */
    #define MIN_RR_INTERVAL                     100                                     /**< Minimum RR interval as returned by the simulated measurement function. */
    #define MAX_RR_INTERVAL                     500                                     /**< Maximum RR interval as returned by the simulated measurement function. */
    #define RR_INTERVAL_INCREMENT               1                                       /**< Value by which the RR interval is incremented/decremented for each call to the simulated measurement function. */
    #define SENSOR_CONTACT_DETECTED_INTERVAL    5000                                    /**< Sensor Contact Detected toggle interval (ms). */
    #define MIN_CONN_INTERVAL                   MSEC_TO_UNITS(600, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.4 seconds). */
    #define MAX_CONN_INTERVAL                   MSEC_TO_UNITS(650, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.65 second). */
    #define SLAVE_LATENCY                       0                                       /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                    MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory time-out (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY      5000                                    /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY       30000                                   /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT        3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
    #define SEC_PARAM_BOND                      1                                       /**< Perform bonding. */
    #define SEC_PARAM_MITM                      0                                       /**< Man In The Middle protection not required. */
    #define SEC_PARAM_LESC                      0                                       /**< LE Secure Connections not enabled. */
    #define SEC_PARAM_KEYPRESS                  0                                       /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES           BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
    #define SEC_PARAM_OOB                       0                                       /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE              7                                       /**< Minimum encryption key size. */
    #define SEC_PARAM_MAX_KEY_SIZE              16                                      /**< Maximum encryption key size. */
    #define DEAD_BEEF                           0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define OSTIMER_WAIT_FOR_QUEUE              2                                       /**< Number of ticks to wait for the timer queue to be ready */
    BLE_BAS_DEF(m_bas);                                                 /**< Battery service instance. */
    BLE_HRS_DEF(m_hrs);                                                 /**< Heart rate service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                 /**< Advertising module instance. */
    static uint16_t m_conn_handle         = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
    static bool     m_rr_interval_enabled = true;                       /**< Flag for enabling and disabling the registration of new RR interval measurements (the purpose of disabling this is just to test sending HRM without RR interval data. */
    static sensorsim_cfg_t   m_battery_sim_cfg;                         /**< Battery Level sensor simulator configuration. */
    static sensorsim_state_t m_battery_sim_state;                       /**< Battery Level sensor simulator state. */
    static sensorsim_cfg_t   m_heart_rate_sim_cfg;                      /**< Heart Rate sensor simulator configuration. */
    static sensorsim_state_t m_heart_rate_sim_state;                    /**< Heart Rate sensor simulator state. */
    static sensorsim_cfg_t   m_rr_interval_sim_cfg;                     /**< RR Interval sensor simulator configuration. */
    static sensorsim_state_t m_rr_interval_sim_state;                   /**< RR Interval sensor simulator state. */
    static ble_uuid_t m_adv_uuids[] =                                   /**< Universally unique service identifiers. */
        {BLE_UUID_HEART_RATE_SERVICE, BLE_UUID_TYPE_BLE},
        {BLE_UUID_BATTERY_SERVICE, BLE_UUID_TYPE_BLE},
        {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
    static TimerHandle_t m_battery_timer;                               /**< Definition of battery timer. */
    static TimerHandle_t m_heart_rate_timer;                            /**< Definition of heart rate timer. */
    static TimerHandle_t m_rr_interval_timer;                           /**< Definition of RR interval timer. */
    static TimerHandle_t m_sensor_contact_timer;                        /**< Definition of sensor contact detected timer. */
    #if NRF_LOG_ENABLED
    static TaskHandle_t m_logger_thread;                                /**< Definition of Logger thread. */
    static void advertising_start(void * p_erase_bonds);
    /**@brief Callback function for asserts in the SoftDevice.
     * @param[in]   line_num   Line number of the failing ASSERT call.
     * @param[in]   file_name  File name of the failing ASSERT call.
    /**@brief Function for handling Peer Manager events.
     * @param[in] p_evt  Peer Manager event.
    static void pm_evt_handler(pm_evt_t const * p_evt)
        bool delete_bonds = false;
        pm_handler_on_pm_evt(p_evt);
        pm_handler_flash_clean(p_evt);
        switch (p_evt->evt_id)
                advertising_start(&delete_bonds);
    /**@brief Function for performing battery measurement and updating the Battery Level characteristic
     *        in Battery Service.
    static void battery_level_update(void)
        ret_code_t err_code;
        uint8_t  battery_level;
        battery_level = (uint8_t)sensorsim_measure(&m_battery_sim_state, &m_battery_sim_cfg);
        err_code = ble_bas_battery_level_update(&m_bas, battery_level, BLE_CONN_HANDLE_ALL);
        if ((err_code != NRF_SUCCESS) &&
            (err_code != NRF_ERROR_INVALID_STATE) &&
            (err_code != NRF_ERROR_BUSY) &&
            (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
            APP_ERROR_HANDLER(err_code);
    /**@brief Function for handling the Battery measurement timer time-out.
     * @details This function will be called each time the battery level measurement timer expires.
     * @param[in] xTimer Handler to the timer that called this function.
     *                   You may get identifier given to the function xTimerCreate using pvTimerGetTimerID.
    static void battery_level_meas_timeout_handler(TimerHandle_t xTimer)
        UNUSED_PARAMETER(xTimer);
        battery_level_update();
    /**@brief Function for handling the Heart rate measurement timer time-out.
     * @details This function will be called each time the heart rate measurement timer expires.
     *          It will exclude RR Interval data from every third measurement.
    static void heart_rate_meas_timeout_handler(TimerHandle_t xTimer)
        static uint32_t cnt = 0;
        uint16_t        heart_rate;
        heart_rate = (uint16_t)sensorsim_measure(&m_heart_rate_sim_state, &m_heart_rate_sim_cfg);
        cnt++;
        err_code = ble_hrs_heart_rate_measurement_send(&m_hrs, heart_rate);
        // Disable RR Interval recording every third heart rate measurement.
        // NOTE: An application will normally not do this. It is done here just for testing generation
        // of messages without RR Interval measurements.
        m_rr_interval_enabled = ((cnt % 3) != 0);
    /**@brief Function for handling the RR interval timer time-out.
     * @details This function will be called each time the RR interval timer expires.
    static void rr_interval_timeout_handler(TimerHandle_t xTimer)
        if (m_rr_interval_enabled)
            uint16_t rr_interval;
            rr_interval = (uint16_t)sensorsim_measure(&m_rr_interval_sim_state,
                                                      &m_rr_interval_sim_cfg);
            ble_hrs_rr_interval_add(&m_hrs, rr_interval);
    /**@brief Function for handling the Sensor Contact Detected timer time-out.
     * @details This function will be called each time the Sensor Contact Detected timer expires.
    static void sensor_contact_detected_timeout_handler(TimerHandle_t xTimer)
        static bool sensor_contact_detected = false;
        sensor_contact_detected = !sensor_contact_detected;
        ble_hrs_sensor_contact_detected_update(&m_hrs, sensor_contact_detected);
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module. This creates and starts application timers.
    static void timers_init(void)
        // Initialize timer module.
        // Create timers.
        m_battery_timer = xTimerCreate("BATT",
                                       BATTERY_LEVEL_MEAS_INTERVAL,
                                       pdTRUE,
                                       NULL,
                                       battery_level_meas_timeout_handler);
        m_heart_rate_timer = xTimerCreate("HRT",
                                          HEART_RATE_MEAS_INTERVAL,
                                          pdTRUE,
                                          NULL,
                                          heart_rate_meas_timeout_handler);
        m_rr_interval_timer = xTimerCreate("RRT",
                                           RR_INTERVAL_INTERVAL,
                                           pdTRUE,
                                           NULL,
                                           rr_interval_timeout_handler);
        m_sensor_contact_timer = xTimerCreate("SCT",
                                              SENSOR_CONTACT_DETECTED_INTERVAL,
                                              pdTRUE,
                                              NULL,
                                              sensor_contact_detected_timeout_handler);
        /* Error checking */
        if ( (NULL == m_battery_timer)
             || (NULL == m_heart_rate_timer)
             || (NULL == m_rr_interval_timer)
             || (NULL == m_sensor_contact_timer) )
            APP_ERROR_HANDLER(NRF_ERROR_NO_MEM);
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
        err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_HEART_RATE_SENSOR_HEART_RATE_BELT);
    static void on_gatt_mtu_event(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    	uint32_t new_data_length;
    	new_data_length = p_gatt->data_length;
    	NRF_LOG_INFO("Data Length Event Recevied: %d", new_data_length);
    /**@brief Function for initializing the GATT module. */
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, on_gatt_mtu_event);
        // Set Gatt MTU Max
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
        APP_ERROR_HANDLER(nrf_error);
     * @details Initialize the Heart Rate, Battery and Device Information services.
        ble_hrs_init_t     hrs_init;
        ble_bas_init_t     bas_init;
        ble_dis_init_t     dis_init;
        uint8_t            body_sensor_location;
        // Initialize Heart Rate Service.
        body_sensor_location = BLE_HRS_BODY_SENSOR_LOCATION_FINGER;
        memset(&hrs_init, 0, sizeof(hrs_init));
        hrs_init.evt_handler                 = NULL;
        hrs_init.is_sensor_contact_supported = true;
        hrs_init.p_body_sensor_location      = &body_sensor_location;
        // Here the sec level for the Heart Rate Service can be changed/increased.
        hrs_init.hrm_cccd_wr_sec = SEC_OPEN;
        hrs_init.bsl_rd_sec      = SEC_OPEN;
        err_code = ble_hrs_init(&m_hrs, &hrs_init);
        // Initialize Battery Service.
        memset(&bas_init, 0, sizeof(bas_init));
        // Here the sec level for the Battery Service can be changed/increased.
        bas_init.bl_rd_sec        = SEC_OPEN;
        bas_init.bl_cccd_wr_sec   = SEC_OPEN;
        bas_init.bl_report_rd_sec = SEC_OPEN;
        bas_init.evt_handler          = NULL;
        bas_init.support_notification = true;
        bas_init.p_report_ref         = NULL;
        bas_init.initial_batt_level   = 100;
        err_code = ble_bas_init(&m_bas, &bas_init);
        // Initialize Device Information Service.
        memset(&dis_init, 0, sizeof(dis_init));
        ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, (char *)MANUFACTURER_NAME);
        dis_init.dis_char_rd_sec = SEC_OPEN;
        err_code = ble_dis_init(&dis_init);
    /**@brief Function for initializing the sensor simulators. */
    static void sensor_simulator_init(void)
        m_battery_sim_cfg.min          = MIN_BATTERY_LEVEL;
        m_battery_sim_cfg.max          = MAX_BATTERY_LEVEL;
        m_battery_sim_cfg.incr         = BATTERY_LEVEL_INCREMENT;
        m_battery_sim_cfg.start_at_max = true;
        sensorsim_init(&m_battery_sim_state, &m_battery_sim_cfg);
        m_heart_rate_sim_cfg.min          = MIN_HEART_RATE;
        m_heart_rate_sim_cfg.max          = MAX_HEART_RATE;
        m_heart_rate_sim_cfg.incr         = HEART_RATE_INCREMENT;
        m_heart_rate_sim_cfg.start_at_max = false;
        sensorsim_init(&m_heart_rate_sim_state, &m_heart_rate_sim_cfg);
        m_rr_interval_sim_cfg.min          = MIN_RR_INTERVAL;
        m_rr_interval_sim_cfg.max          = MAX_RR_INTERVAL;
        m_rr_interval_sim_cfg.incr         = RR_INTERVAL_INCREMENT;
        m_rr_interval_sim_cfg.start_at_max = false;
        sensorsim_init(&m_rr_interval_sim_state, &m_rr_interval_sim_cfg);
    /**@brief   Function for starting application timers.
     * @details Timers are run after the scheduler has started.
    static void application_timers_start(void)
        // Start application timers.
        if (pdPASS != xTimerStart(m_battery_timer, OSTIMER_WAIT_FOR_QUEUE))
        if (pdPASS != xTimerStart(m_heart_rate_timer, OSTIMER_WAIT_FOR_QUEUE))
        if (pdPASS != xTimerStart(m_rr_interval_timer, OSTIMER_WAIT_FOR_QUEUE))
        if (pdPASS != xTimerStart(m_sensor_contact_timer, OSTIMER_WAIT_FOR_QUEUE))
    /**@brief Function for handling the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module which
     *          are passed to the application.
     *          @note All this function does is to disconnect. This could have been done by simply
     *                setting the disconnect_on_fail config parameter, but instead we use the event
     *                handler mechanism to demonstrate its use.
     * @param[in]   p_evt   Event received from the Connection Parameters Module.
    /**@brief Function for handling a Connection Parameters error.
    /**@brief Function for initializing the Connection Parameters module. */
        cp_init.start_on_notify_cccd_handle    = m_hrs.hrm_handles.cccd_handle;
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
                NRF_LOG_INFO("Fast advertising.");
            case BLE_ADV_EVT_SLOW:
                NRF_LOG_INFO("Slow advertising.");
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
    //@ble
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
        uint32_t ram_start = 0;
        // Enable BLE stack.
     * @param[in]   event   Event generated by button press.
    static void bsp_event_handler(bsp_event_t event)
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
            case BSP_EVENT_WHITELIST_OFF:
    /**@brief Function for the Peer Manager initialization. */
    static void peer_manager_init(void)
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
    /**@brief Clear bond information from persistent storage. */
    static void delete_bonds(void)
        NRF_LOG_INFO("Erase bonds!");
        err_code = pm_peers_delete();
    /**@brief Function for initializing the Advertising functionality. */
        ble_advertising_init_t init;
        init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance      = true;
        init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
        init.config.ble_adv_fast_interval = APP_ADV_FAST_INTERVAL;
        init.config.ble_adv_fast_timeout  = APP_ADV_FAST_DURATION;
        init.config.ble_adv_slow_enabled  = true;
        init.config.ble_adv_slow_interval = APP_ADV_SLOW_INTERVAL;
        init.config.ble_adv_slow_timeout  = APP_ADV_SLOW_DURATION;
    static void log_init(void)
        bsp_event_t startup_event;
        err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    /**@brief Function for starting advertising. */
        bool erase_bonds = *(bool*)p_erase_bonds;
        if (erase_bonds)
            delete_bonds();
            // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
            ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    static void gatt_mtu_set(uint16_t att_mtu)
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, att_mtu);
        /*err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, att_mtu);
        APP_ERROR_CHECK(err_code);*/
    static void conn_evt_len_ext_set(bool status)
        ble_opt_t  opt;
        memset(&opt, 0x00, sizeof(opt));
        opt.common_opt.conn_evt_ext.enable = status ? 1 : 0;
        err_code = sd_ble_opt_set(BLE_COMMON_OPT_CONN_EVT_EXT, &opt);
    static void data_len_set(uint8_t value)
        err_code = nrf_ble_gatt_data_length_set(&m_gatt, BLE_CONN_HANDLE_INVALID, value);
    #if NRF_LOG_ENABLED
    /**@brief Thread for handling the logger.
     * @details This thread is responsible for processing log entries if logs are deferred.
     *          Thread flushes all log entries and suspends. It is resumed by idle task hook.
     * @param[in]   arg   Pointer used for passing some arbitrary information (context) from the
     *                    osThreadCreate() call to the thread.
    static void logger_thread(void * arg)
        UNUSED_PARAMETER(arg);
        while (1)
            NRF_LOG_FLUSH();
            vTaskSuspend(NULL); // Suspend myself
    #endif //NRF_LOG_ENABLED
    /**@brief A function which is hooked to idle task.
     * @note Idle hook must be enabled in FreeRTOS configuration (configUSE_IDLE_HOOK).
    void vApplicationIdleHook( void )
    #if NRF_LOG_ENABLED
         vTaskResume(m_logger_thread);
    /**@brief Function for initializing the clock.
    static void clock_init(void)
        ret_code_t err_code = nrf_drv_clock_init();
    /**@brief Function for application main entry.
        bool erase_bonds;
        // Initialize modules.
        log_init();
        clock_init();
        // Do not start any interrupt that uses system functions before system initialisation.
        // The best solution is to start the OS before any other initalisation.
    #if NRF_LOG_ENABLED
        // Start execution.
        if (pdPASS != xTaskCreate(logger_thread, "LOGGER", 256, NULL, 1, &m_logger_thread))
        // Activate deep sleep mode.
        SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
        // Configure and initialize the BLE stack.
        ble_stack_init();
        timers_init();
        gap_params_init();
        gatt_init();
        advertising_init();
        services_init();
        sensor_simulator_init();
        conn_params_init();
        peer_manager_init();
        application_timers_start();
        // Set Radio Settings
        gatt_mtu_set(NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
        conn_evt_len_ext_set(true);
        data_len_set(NRF_SDH_BLE_GAP_DATA_LENGTH);
        // Create a FreeRTOS task for the BLE stack.
        // The task will run advertising_start() before entering its loop.
        nrf_sdh_freertos_init(advertising_start, &erase_bonds);
        NRF_LOG_INFO("HRS FreeRTOS example started.");
        // Start FreeRTOS scheduler.
        vTaskStartScheduler();
        for (;;)
            APP_ERROR_HANDLER(NRF_ERROR_FORBIDDEN);
    2577.FreeRTOSConfig.h
    40146.sdk_config.h
  • This is exactly the error I'm seeing.  Have you solved this Jeff?  Any comment from Nordic? ?
  • I could not reproduce it . Can you help me to reproduce this error Dave?
  • I just took the freeRTOS example and increased the MTU to 247 and DL to 251.  Works fine until you connect.  It crashes during connection
  • sorry Dave, this thread skipped my queue, I did not see that you replied. Do you still have this problem ? I am confident that due to my delay in answer, you must have dug into it yourself. If you found the solution, can you please update us.
