nRF Connect Error "NRF_ERROR_TIMEOUT"
I am trying to use the nRF Connect v1.0 RC with the pca10040 board. I followed the instructions of your [page] and when i open the serial port i got an error (Error occurred opening serial port. (NRF_ERROR_TIMEOUT)) as shown in the attached figure. I programmed the “connectivity_115k2_with_s132_2.0.1.hex” file by two ways: via drag and drop and by nrfjprog tool (version 8.4 and also 8.0) and i programmed ble example applications (with and without uart initialisation) with Keil uVision5. I noticed that the board receives the ASCII characters “*” “NUL” “ENQ” “NUL” “*” “*” and not respond any data. Any suggestion what i might be doing wrong or not doing? image description
  • Ok, finally I looked it over with colleges and we found "smoke signes" on the board. A college had modified it for current measurements. So maybe not worth staying to long on this device. I will order a new one.
  • I am facing the same problem with "NRF_ERROR_TIMEOUT". nRF Connect v2.2.1 was working earlier this week, but today suddenly it stopped working. I have uninstalled everything from Nordic and Segger and now I have reinstalled nRF Connect v2.2.1. It installs SEGGER JLink_V620b automatically I think. I also erased my device with
    nrfjprog --eraseall
    before running nRF Connect.
    This is my logfile:
    2018-01-26T12:04:06.337Z INFO Application data folder: C:\Users\xxxxxx\AppData\Roaming\nrfconnect
    2018-01-26T12:04:31.617Z INFO Opening adapter connected to COM16
    2018-01-26T12:04:32.133Z INFO Successfully opened COM16. Baud rate: 1000000. Flow control: none. Parity: none.
    2018-01-26T12:04:32.133Z DEBUG State change: STATE_START -> STATE_RESET
    2018-01-26T12:04:32.133Z DEBUG        1 ->  []
                   type:          RESERVED_5 reliable: no seq#:0 ack#:0 payload_length:0 data_integrity:0 err_code:0
    2018-01-26T12:04:32.134Z INFO Reset performed on adapter COM16
    2018-01-26T12:04:32.432Z DEBUG State change: STATE_RESET -> STATE_UNINITIALIZED
    2018-01-26T12:04:32.432Z DEBUG        2 ->  [01 7e ]
                   type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:2 data_integrity:0 err_code:0
                   [SYNC]
    2018-01-26T12:04:32.434Z DEBUG     1/ 0 <-  [02 7d ]
                   [SYNC_RESP]
    2018-01-26T12:04:32.434Z DEBUG State change: STATE_UNINITIALIZED -> STATE_INITIALIZED
    2018-01-26T12:04:32.434Z DEBUG        3 ->  [03 fc 11 ]
                   type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:3 data_integrity:0 err_code:0
                   [CONFIG [ sliding-window-size:1 out-of-frame:0 data-integrity-check-type:1 version-number:0 ]]
    2018-01-26T12:04:32.684Z DEBUG        4 ->  [03 fc 11 ]
    2018-01-26T12:04:32.934Z DEBUG        5 ->  [03 fc 11 ]
    2018-01-26T12:04:32.936Z DEBUG     2/ 0 <-  [01 7e ]
                   [SYNC]
    2018-01-26T12:04:32.936Z DEBUG        6 ->  [02 7d ]
                   [SYNC_RESP]
    2018-01-26T12:04:33.184Z DEBUG        7 ->  [03 fc 11 ]
    2018-01-26T12:04:33.185Z DEBUG     3/ 0 <-  [04 7b 11 ]
                   [CONFIG_RESP [ sliding-window-size:1 out-of-frame:0 data-integrity-check-type:1 version-number:0 ]]
    2018-01-26T12:04:33.435Z DEBUG        8 ->  [03 fc 11 ]
    2018-01-26T12:04:33.435Z DEBUG State change: STATE_INITIALIZED -> STATE_FAILED
    2018-01-26T12:04:33.436Z DEBUG     4/ 0 <-  [04 7b 11 ]
    2018-01-26T12:04:33.438Z DEBUG     5/ 0 <-  [03 fc 11 ]
    2018-01-26T12:04:33.940Z DEBUG     6/ 0 <-  [03 fc 11 ]
    2018-01-26T12:04:34.139Z ERROR Error occured when opening port. Errorcode: NRF_ERROR_TIMEOUT (0xd)
  • I wanted to comment that I am also experiencing this, but my logfile was too big for the comment field. See my answer above.
    could you try to downgrade nRF Connect Core to version 2.2.0 (I assume you are using the latest v2.2.1 now). There was a change in v2.2.1 that might have contributed to what you are seeing. A new version that includes a fix is soon to be released.
  • Yes! Version 2.2.0 is actually working! In this version my device also shows up when I have set the "MSDDisable" (disable mass storage functionality) that also does not work in 2.2.1
