TWI doesn't work when a handler is set
I'm learning how to use TWI with the nRF52 PDK, and I have it connected to a LSM6DS3 module for testing.
When initializing the TWI, if I use the following line, it works great:
ret_code_t err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);
However, I run into a problem when I pass an event handler, like so:
ret_code_t err_code = nrf_drv_twi_init(&m_twi, &twi_config, twi_handler, NULL);
It will execute the transfer once (verified on an oscilloscope), but the event handler never gets called, and the app appears to freeze.
I've stripped the event handler down to the bare essentials:
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context){
   NRF_LOG_INFO("twi event\r\n");
   NRF_LOG_FLUSH();
And in main(), here's how I call it:
    ret_code_t err_code;
    uint8_t address = 0x6B;
    uint8_t registerAddr = 0x0f;
    NRF_LOG_INFO("TWI scanner.\r\n");
    NRF_LOG_FLUSH();
   twi_init();
   nrf_drv_twi_xfer_desc_t xfer = NRF_DRV_TWI_XFER_DESC_TXRX(address, &registerAddr, 1, &byteWeReceived, 1);
    while(1){
    	err_code = nrf_drv_twi_xfer(&m_twi, &xfer, 0);
    	if (err_code == NRF_SUCCESS)
			NRF_LOG_INFO("sent command. got 0x%x\r\n", byteWeReceived);
	}else{
			NRF_LOG_INFO("had a problem\r\n");
		NRF_LOG_FLUSH();
    	nrf_delay_ms(1000);
I have verified with an oscilloscope that that the no-handler version works just fine--it sends the command every 1000 ms with no issues.
Is there something I'm doing incorrectly when initializing the TWI, or that I'm not handling correctly in the event handler?
  • I'm getting the same problem. I've removed all NRF_LOG_* from the interrupt handler, but it still isn't called.
    const nrf_drv_twi_config_t twi_SI7021_config = {
           .scl                = ARDUINO_SCL_PIN,
           .sda                = ARDUINO_SDA_PIN,
           .frequency          = NRF_TWI_FREQ_100K,
           .interrupt_priority = APP_IRQ_PRIORITY_LOW, // I've tried HIGH
           .clear_bus_init     = false
    err_code = nrf_drv_twi_init(&m_twi, &twi_SI7021_config, twi_handler, NULL);
  • What is not called? The interrupt handler? I recommend that you post a new thread where you described your code and the issue in more details. This will make it easier to help you get your issue sorted out.
1 2
