SDK14 ble_periphal example dont work
Hi, i downloaded new SDK14 with example, after i upload hex from example in ble_peripheral/ble_app_hrs I use s132 / nrf52
program stuck here :
ret_code_t nrf_sdh_enable_request(void)
    ret_code_t ret_code;
    if (m_nrf_sdh_enabled)
    m_nrf_sdh_continue = true;
    // Notify observers about SoftDevice enable request.
    if (sdh_request_observer_notify(NRF_SDH_EVT_ENABLE_REQUEST) == NRF_ERROR_BUSY)
        // Enable process was stopped.
        return NRF_SUCCESS;
    // Notify observers about starting SoftDevice enable process.
    sdh_state_observer_notify(NRF_SDH_EVT_STATE_ENABLE_PREPARE);
    nrf_clock_lf_cfg_t const clock_lf_cfg =
        .source        = NRF_SDH_CLOCK_LF_SRC,
        .rc_ctiv       = NRF_SDH_CLOCK_LF_RC_CTIV,
        .rc_temp_ctiv  = NRF_SDH_CLOCK_LF_RC_TEMP_CTIV,
    #ifdef S132
        .accuracy      = NRF_SDH_CLOCK_LF_XTAL_ACCURACY
    #else
        .xtal_accuracy = NRF_SDH_CLOCK_LF_XTAL_ACCURACY
    #ifdef ANT_LICENSE_KEY
        ret_code = sd_softdevice_enable(&clock_lf_cfg, app_error_fault_handler, ANT_LICENSE_KEY);
    #else
        ret_code = sd_softdevice_enable(&clock_lf_cfg, app_error_fault_handler);
    if (ret_code != NRF_SUCCESS)
        return ret_code;
on ret_code = sd_softdevice_enable(&clock_lf_cfg, app_error_fault_handler);
same problem is, if i recomplile whole project a load new one.
could someone help me, where is the problem ? regards
  • So how did you solve it finally? I had the same issue for board PTR5618, set NRF_SDH_CLOCK_LF_SRC to 0 but then sd_softdevice_enable would give me NRF_ERROR_INVALID_PARAM and just abort the program since I call APP_ERROR_CHECK after nrf_sdh_enable_request (as in the examples).
  • I had the same issue, my custom board has no LF clock at all (no solder jumper that can enable it)
    For me the solution was to set "#define NRF_SDH_CLOCK_LF_RC_CTIV 4" which was 0 before.
    My clock configuration is now:
    // <0=> NRF_CLOCK_LF_SRC_RC
    // <1=> NRF_CLOCK_LF_SRC_XTAL
    // <2=> NRF_CLOCK_LF_SRC_SYNTH
    #ifndef NRF_SDH_CLOCK_LF_SRC
    #define NRF_SDH_CLOCK_LF_SRC 0
    // <o> NRF_SDH_CLOCK_LF_RC_CTIV - SoftDevice calibration timer interval.
    #ifndef NRF_SDH_CLOCK_LF_RC_CTIV
    // <o> NRF_SDH_CLOCK_LF_RC_TEMP_CTIV - SoftDevice calibration timer interval under constant temperature.
    // <i> How often (in number of calibration intervals) the RC oscillator shall be calibrated
    // <i>  if the temperature has not changed.
    #ifndef NRF_SDH_CLOCK_LF_RC_TEMP_CTIV
    #define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 0
    // <o> NRF_SDH_CLOCK_LF_XTAL_ACCURACY  - External crystal clock accuracy used in the LL to compute timing windows.
    // <0=> NRF_CLOCK_LF_XTAL_ACCURACY_250_PPM
    // <1=> NRF_CLOCK_LF_XTAL_ACCURACY_500_PPM
    // <2=> NRF_CLOCK_LF_XTAL_ACCURACY_150_PPM
    // <3=> NRF_CLOCK_LF_XTAL_ACCURACY_100_PPM
    // <4=> NRF_CLOCK_LF_XTAL_ACCURACY_75_PPM
    // <5=> NRF_CLOCK_LF_XTAL_ACCURACY_50_PPM
    // <6=> NRF_CLOCK_LF_XTAL_ACCURACY_30_PPM
    // <7=> NRF_CLOCK_LF_XTAL_ACCURACY_20_PPM
    #ifndef NRF_SDH_CLOCK_LF_XTAL_ACCURACY
    #define NRF_SDH_CLOCK_LF_XTAL_ACCURACY 7
  • How did you resolve the issue. I have the same problem
  • Hi . I suggest you start another thread. Please include as many details as possible about what SDK and Softdevice versions you are using etc.
  • Thanks for sharing. Had the same problem. All fixed now!
