I think Zephyr OS has better support for "Bluetooth Mesh" than Nordic own MESH SDK
Is nordic has any plan to release MESH related examples which support this play.google.com/.../details Android APP ?
Hi there, I tried to run meshctl tool with bluez-5.48 ubuntu 16.04(laptop with bluetooth adapter attached inside), it seems doesn't work well:
Local config directory not provided. Waiting to connect to bluetoothd...Failed to parse local node configuration file local_node.json
Do you have any idea what's wrong with it?
B.R.
Thanks for comments. I copied *.json file from git pull git://git.kernel.org/pub/scm/bluetooth/bluez.git
to bluez-5.48/mesh directory and meshctl works.
Many thanks.
Hi! You mentioned that Zephyr was in the process of launching support so that provisioning & configuration setting will get save into on board flash. Is their mesh_demo sample an example of this? By modifying this file, will it be possible to run the network with an Advertising Bearer, and therefore skipping the use of BlueZ? Thanks for your support!
