nrf52832 Uart SDK14
Context : I am using a nrf52832 to communicate via UART to a STM32 on a custom board. I've based my work on the Ble nus service example. Main change from the DK is that i don't have an external 32khz so i enabled NRF_CLOCK_LF_SRC_RC
I recently updated the nrf52832 code from SDK12/s132 version 3.0 to SDK14 /s132 version 5.0 because i had issues with some Android devices.
Problem : The BLE part is doing fine now with all the devices that were causing trouble (advertisement, connection, characteristic reading/writing) but the UART part is now unstable.
Hardware flow control is enabled UART_DEFAULT_CONFIG_HWFC, baudrate is set to 115200. On the SDK14, i've tried UART_EASY_DMA_SUPPORT but it's not working, so i switched to using UART_LEGACY_SUPPORT.
At first, uart communication is good at transmitting / receiving but after a while, the connexion hang and i have to reset the whole board. The uart_event_handle doesn't seems to have a APP_UART_COMMUNICATION_ERROR or APP_UART_FIFO_ERROR event but what happen is a high state on the CTS pin of the nrf52. Also, UART_RX_BUF_SIZE value seems to change the delay/latency after which i have this problem.
After debugging i did get those two info from the uart :
EVENTS_CTS 1 EVENTS_NCTS 1 EVENTS_ERROR 0 ERRORSRC 0
Can someone give me hints on what to look after ?
(already saw devzone.nordicsemi.com/.../ and checked the pinout)
EDIT: the high state is on the RTS pin of the nrf52 not the CTS (blue line is RTS, yellow is RX)
image description
  • Since it worked fine before migrating to SDK 14, there is probably something you missed when you migrated. Could you explain the steps you did when you migrated to SDK 14 ?
  • Sorry I didn't took the time to explain all the steps but i though it would take too long to do it. At the same time I did restart from scratch the migration and managed to find the problem.
    As i said, i disabled the easyDma ( #define UART_EASY_DMA_SUPPORT 0 #define UART0_CONFIG_USE_EASY_DMA 0) but what did the trick was commenting the line #define UARTE_PRESENT in nrf52832_peripherals.h. Since then, the uart with HW flow control is working fine at 115200. If anyone have an explanation, i would be glad to hear it. I will set this comment as an answer if no tech tell me i'm wrong.
    Thanks for the support Sigurd !
