FDS_ERR_NOT_FOUND issue of yps_storage_find in sdk 14.0.1
I implemented overall flow related with FDS function including garbage collection, when I check garbage collection, it is ok, it confirm that the data will be saved with writing or updating function in event handler, please refer the following codes, (refer to FDS_EVT_GC in the log)
but I have one problem, FDS_ERR_NOT_FOUND error is sometimes happened with yps_storage_find, when I check the flow of codes, it is happened in yps_storage_write & yps_storage_read function, so I can't read the data at that time,
I can't know the reason, I repeatedly tried to delete record before writing data, so it should be done as to fds_record_write function, is it right ?
please help to let me know the reason and what it is wrong, thankful for your support in advance,
thanks.
Error log :
Event: FDS_EVT_DEL_RECORD received (FDS_SUCCESS)
Deleted record ID: 242 0x0
yps_storage_find not found 0x1111 0x3333
Event: FDS_EVT_WRITE received (FDS_SUCCESS)
fds_record_write : 0 243
yps_password = 159
Uncalibrated time:	01/01/18 - 15:26:40
Calibrated time:	01/01/18 - 15:26:40
DelEvent: FDS_EVT_DEL_RECORD received (FDS_SUCCESS)
eted record ID: 243 0x0
fds_record_write : 0 244
yps_password = 160
Uncalibrated time:	01/01/18 - 15:26:41
Calibrated time:	01/01/18 - 15:26:41
Deleted record ID: 244 0x0
fds_record_write : 0 245
yps_storage_read not found 0xEvent: FDS_EVT_WRITE received (FDS_SUCCESS)
1111 0x3333
yps_password = 160
Uncalibrated time:	01/01/18 - 15:26:42
Calibrated time:	01/01/18 - 15:26:42
Deleted record ID: 245 0x0
fds_record_write : 0 246
yps_password = 162
Uncalibrated time:	01/01/18 - 15:26:43
Calibrated time:	01/01/18 - 15:26:43
firstly, in the main routine,
if(password[0] == 250)
	password[0] = 0;
password[0]++;
yps_storage_password_delete();
err_code = yps_storage_password_write(password);
uint8_t yps_password[YPS_PASSWORD_LENGTH];
err_code = yps_storage_password_read(yps_password);
printf("yps_password = %d \r\n", yps_password[0]);
_1ms_count = 0;
and then each functions of FDS,
#include <string.h>
#include "hal_fds_module.h"
#include "fds.h"
#include "app_error.h"
#include "app_util.h"
#include "app_util_bds.h"
//#pragma pack(push, 4)
//struct schedule_db_schema {
//	uint8_t day;
//	uint8_t hour;
//	uint8_t minute;
//static struct schedule_db_schema db_schema;// __ALIGN(4);
//#pragma pack(pop)
static volatile bool 		m_fds_evt_init = false;
static volatile bool 		m_pending_write  = false;      /**< Flag used to preserve write request during Garbage Collector activity. */
static volatile bool 		m_pending_update = false;      /**< Flag used to preserve update request during Garbage Collector activity. */
static uint16_t	       		m_pending_msg_key    = 0;//love_0124
static uint32_t        		m_pending_msg_size   = 0;    /**< Pending write/update request data size. */
static uint8_t const * 		m_p_pending_msg_buff = NULL; /**< Pending write/update request data pointer. */
static fds_record_desc_t  	record_desc;            /**< Record descriptor. */
static fds_record_t       	rec;                 /**< Record description used for writes. */
/* Array to map FDS return values to strings. */
char const * fds_err_str[] =
    "FDS_SUCCESS",
    "FDS_ERR_OPERATION_TIMEOUT",
    "FDS_ERR_NOT_INITIALIZED",
    "FDS_ERR_UNALIGNED_ADDR",
    "FDS_ERR_INVALID_ARG",
    "FDS_ERR_NULL_ARG",
    "FDS_ERR_NO_OPEN_RECORDS",
    "FDS_ERR_NO_SPACE_IN_FLASH",
    "FDS_ERR_NO_SPACE_IN_QUEUES",
    "FDS_ERR_RECORD_TOO_LARGE",
    "FDS_ERR_NOT_FOUND",
    "FDS_ERR_NO_PAGES",
    "FDS_ERR_USER_LIMIT_REACHED",
    "FDS_ERR_CRC_CHECK_FAILED",
    "FDS_ERR_BUSY",
    "FDS_ERR_INTERNAL",
/* Array to map FDS events to strings. */
static char const * fds_evt_str[] =
    "FDS_EVT_INIT",
    "FDS_EVT_WRITE",
    "FDS_EVT_UPDATE",//love_0124 Event for fds_record_update.
    "FDS_EVT_DEL_RECORD",//love_0124 Event for fds_record_delete.
    "FDS_EVT_DEL_FILE",
    "FDS_EVT_GC",
 * @brief   Prepare record structure for write or update request.
 * @details Configures file ID, record KEY, data to be written and message length.
 * @param[in] buff  Pointer to the YPS message to be stored in FLASH.
 * @param[in] size  Size of YPS message.
static void yps_file_prepare_record(uint16_t key, uint8_t const * p_buff, uint32_t size)
	// Set up record.
	rec.file_id           = FILE_ID;
	rec.key               = key;
	rec.data.p_data       = p_buff;
	rec.data.length_words = BYTES_TO_WORDS(size); // Align data length to 4 bytes.
static void yps_storage_fds_evt_handler(fds_evt_t const * const p_fds_evt)
	ret_code_t ret;
	printf("Event: %s received (%s) \r\n", fds_evt_str[p_fds_evt->id], fds_err_str[p_fds_evt->result]);
	switch (p_fds_evt->id)
		case FDS_EVT_INIT:
//			printf("FDS_EVT_INIT %x\r\n", p_fds_evt->result);
			if (p_fds_evt->result != FDS_SUCCESS)
				printf("FDS_EVT_INIT Initialization failed\r\n");
				m_fds_evt_init = true;
		case FDS_EVT_WRITE:
//			printf("FDS_EVT_WRITE %x\r\n", p_fds_evt->result);
//			if (p_fds_evt->result == FDS_SUCCESS)
//				printf("FDS_EVT_WRITE FDS_SUCCESS\r\n");
//			else
//				printf("FDS_EVT_WRITE Failed!!!\r\n");
		case FDS_EVT_UPDATE:
//			printf("FDS_EVT_UPDATE %x\r\n",p_fds_evt->result);
		case FDS_EVT_DEL_RECORD:
//			printf("FDS_EVT_DEL_RECORD %x\r\n", p_fds_evt->result);
//			ret = fds_gc();
//			APP_ERROR_CHECK(ret);
		case FDS_EVT_DEL_FILE:
//			printf("FDS_EVT_DEL_FILE %x\r\n",p_fds_evt->result);
		case FDS_EVT_GC:
			//Perform pending write/update.
			if (m_pending_write)
				printf("FDS_EVT_GC m_pending_write %x\r\n", p_fds_evt->result);
				// Prepare record structure.
				yps_file_prepare_record(m_pending_msg_key, m_p_pending_msg_buff, m_pending_msg_size);
				ret = fds_record_write(&record_desc, &rec);
				printf("FDS_EVT_GC fds_record_write : %x %d \r\n", ret, record_desc.record_id);
			else if (m_pending_update)
				printf("FDS_EVT_GC m_pending_update %x\r\n", p_fds_evt->result);
				ret = fds_record_update(&record_desc, &rec);
				printf("FDS_EVT_GC fds_record_update : %x %d \r\n", ret, record_desc.record_id);
ret_code_t yps_storage_init(void) {
	ret_code_t ret = fds_register(yps_storage_fds_evt_handler);
	if (ret != FDS_SUCCESS) {
		return ret;
	ret = fds_init();
		return ret;
	fds_stat_t stat = {0};
	ret = fds_stat(&stat);//love_0123
	return NRF_SUCCESS;
bool yps_storage_find(uint16_t file_id, uint16_t key, fds_record_desc_t * p_desc) {
	ret_code_t ret;
	fds_find_token_t ftok;
	memset(&ftok, 0, sizeof(fds_find_token_t));
	ret = fds_record_find(file_id, key, p_desc, &ftok);
	if (ret == FDS_SUCCESS) {
		printf("fds_record_find Record ID = %d\r\n", p_desc->record_id);
		return true;
	printf("yps_storage_find not found 0x%x 0x%x\r\n", file_id, key);
	return false;
ret_code_t yps_storage_write(uint16_t file_id, uint16_t key, uint8_t const * p_data, uint16_t length_bytes) {
	ret_code_t ret;
//	fds_record_desc_t record_desc;
//	memset(&record_desc, 0, sizeof(record_desc));
//	fds_record_t const rec =
//		.file_id           = file_id,
//		.key               = key,
//		.data.p_data       = &p_data,
//		.data.length_words = 1//BYTES_TO_WORDS(length_bytes)
	yps_file_prepare_record(key, p_data, length_bytes);
	if(yps_storage_find(file_id, key, &record_desc))
		// update
		printf("fds_record_update : %x %d \r\n", ret, record_desc.record_id);
		if (ret == FDS_ERR_NO_SPACE_IN_FLASH)//love_0124
		        // If there is no space, preserve write request and call Garbage Collector.
		        m_pending_update     = true;
		        m_pending_msg_key    = key;//love_0124
		        m_pending_msg_size   = length_bytes;
		        m_p_pending_msg_buff = p_data;
			ret = fds_gc();
		// new
		printf("fds_record_write : %x %d \r\n", ret, record_desc.record_id);
			// If there is no space, preserve update request and call Garbage Collector.
		        m_pending_write      = true;
			ret = fds_gc();
	return ret;
ret_code_t yps_storage_read(uint16_t file_id, uint16_t key, uint8_t * p_data) {
	ret_code_t ret;
	fds_flash_record_t  	flash_record = {0};
	fds_find_token_t 	ftok = {0};
//	memset(&ftok, 0x00, sizeof(fds_find_token_t));
	ret = fds_record_find(file_id, key, &record_desc, &ftok);
	if(ret != FDS_SUCCESS)
		printf("yps_storage_read not found 0x%x 0x%x\r\n", file_id, key);
		return ret;
	ret = fds_record_open(&record_desc, &flash_record);
		return ret;
	// Access the record through the flash_record structure.
	memcpy(p_data, flash_record.p_data, (flash_record.p_header->length_words * sizeof(uint32_t)));//sizeof(uint32_t) BYTES_PER_WORD
	// Close the record when done.
	ret = fds_record_close(&record_desc);
		return ret;
	return ret;
ret_code_t yps_storage_find_and_delete(uint16_t file_id, uint16_t key)
	ret_code_t ret;
//	memset(&record_desc, 0, sizeof(fds_record_desc_t));
	// Loop and find records with same ID and rec key and mark them as deleted.
	while (fds_record_find(file_id, key, &record_desc, &ftok) == FDS_SUCCESS)
		ret = fds_record_delete(&record_desc);
		printf("Deleted record ID: %d 0x%x\r\n", record_desc.record_id, (unsigned int) ret);
//	// call the garbage collector to empty them, don't need to do this all the time, this is just for demonstration
//	ret = fds_gc();
//	if (ret != FDS_SUCCESS)
//		return ret;
	return NRF_SUCCESS;
ret_code_t yps_storage_id_write(uint8_t * p_id) {
	return yps_storage_write(FILE_ID, REC_KEY_ID, p_id, YPS_ID_LENGTH);
ret_code_t yps_storage_password_write(uint8_t * p_password) {
	return yps_storage_write(FILE_ID, REC_KEY_PASSWORD, p_password, YPS_PASSWORD_LENGTH);
ret_code_t yps_storage_id_read(uint8_t * p_id) {
	ret_code_t ret = yps_storage_read(FILE_ID, REC_KEY_ID, p_id);
	return ret;
ret_code_t yps_storage_password_read(uint8_t * p_password) {
	ret_code_t ret = yps_storage_read(FILE_ID, REC_KEY_PASSWORD, p_password);
	return ret;
ret_code_t yps_storage_id_delete(void) {
	return yps_storage_find_and_delete(FILE_ID, REC_KEY_ID);
ret_code_t yps_storage_password_delete(void) {
	return yps_storage_find_and_delete(FILE_ID, REC_KEY_PASSWORD);
bool get_fds_evt_init(void) {
	return m_fds_evt_init;
  • Hi, Petter,
    sorry for any confusion, I confused this agenda with other...sorry...
    for only this agenda, currently I am not using for delete_record function,
    instead, I confirmed the size of memory by using  DFU_APP_DATA_RESERVED, it can be defined by user in sdk_config.h... and it is related with the region of app data, when verifying by myself, the data can kept in the region of app data(maybe) after doing DFU... I tried to verify for many times by firstly writing some data with field value, after that, I tried to read the data with the same field data by using fds function(not fstorage function). so I learned that if can confirm the size of necessary data with DFU_APP_DATA_RESERVED in the region of app data (maybe, I am'not sure that the region of DFU_APP_DATA_RESERVED  is the region of app data),  I don't need to delete the record every time (when writing new data in the same field) because new data will be updated (not written) by update_fds function.. is it right ?
    so currently I can't find the error related with find function because I am not using delete_record_fds function. how about my usage ? is it right for mass production ?
    please help to let me have the confirmation about my code...
    thanks.
  • You can check the start and end address used by Fstorage by putting breakpoint in flash_bounds_set() in fds.c. If you have a bootloader flash_end_addr() will account for that and use the flash pages below. The SDK examples typically reserves 3 flash pages.
    DFU_APP_DATA_RESERVED determines how many flash pages below the bootloader that will be reserved (not erased when doing DFU). This should match the number of pages used by Fstorage, typically 3.
