copy assignment not allowed in union
I am attempting to do some development using the usbd_hid_generic example peripheral code. I am using some C++ libraries in this project, however there is syntax in the usbd code (specifically in the app_usbd_class_base.h file) that fails to compile. This is making it difficult for me to be able to integrate my new code with the old code. To simplify things, I will just outline changing the main.c file to main.cpp in the base example program and describe what happens. If this can be fixed, I should be able to work out the rest. I am using gcc-arm-none-eabi for compilation on a Linux OS and I am using SKD v. 13, though I have also tried this under v. 14 with the same results.
Step 1: Rename main.c to main.cpp and change the corresponding entry in the Makefile.
Step 2: Compile the code - fails.
The first error is: [...]/app_usbd_class_base.h:674:5: sorry, unimplemented: non-trivial designated initializers not supported
According to the following, it seems it should be possible to compile using older versions of C++, but designated initializer lists are not supported in current C++ standards. stackoverflow.com/.../why-does-c11-not-support-designated-initializer-lists-as-c99
I attempted a workaround by setting -std=c++98, but that resulted in another error.
There is an additional error: [...]/app_usbd_class_base.h:586:11: error: member 'app_usbd_hid_mouse_u:: app_usbd_hid_mouse_u::specific' with copy assignment operator not allowed in union.
Possible options:
I am looking for how to integrate the usbd libraries within a C++ project. If people have some insights, please share. So far, I figure some workarounds are for me to set up code to implement the C++ libraries I am working with in C, or I can write access functions to wrap C++ code in extern "C" blocks and leave the usbd code calls in a C context. I think I will try the second option first, but it seems that it should be more straightforward to use Nordic usbd libraries within C++ projects.
  • The USB interface uses a struct, not a class. The header files themselves include extern "C" declarations as well, but I added a few additional blocks in main.cpp; no difference.
  • @nvp Are the errors just located in app_usbd_class_base.h? Or did you add some custom code?
  • I will eventually be using some custom C++ code to communicate with some peripheral devices, but in the context of this question, the problem can be demonstrated without introducing any additional code to the usbd_hid_generic peripheral example. Some of the code in the original app_usbd_class_base.h is incompatible with the C++ standards as enforced by the arm-none-eabi-g++ compiler.
    In order to work around the problem, I implemented option 2 from my original post. I reverted main back to a C program and I wrote a new wrapper.h and wrapper.cpp to interface the C++ classes in the libraries that I was using. These wrapper functions took Class::f(x,y,z) and made a C-style function class_f(void* instance, x, y, z) that could bridge the gap. Using extern "C" here provides C-style hooks. Since all calls to the usbd are exclusively in main.c, compiled by gcc, this avoids the problem.
  • C++ cannot skip definitions in between. All definitions above the one that causes the error has to be filled in order. You can however skip all bellow. For example :
    static const app_usbd_config_t usbd_config = {
        .ev_state_proc = usbd_user_ev_handler
    Will cause the error but :
        .ev_isr_handler = NULL,
    will not.
    for union stuff :
    typedef struct a {
    	int z;
    	union {
    		int b;
    		struct {
    			uint8_t c;
    			uint16_t d;
    		} f;
    } A;
    A x = {
    	.z = 0,
    	{ .f = {.c = 1, .d = 2} }
    A y = {
    	.z = 0,
    	{ .b = 3 }
