GPIO pins don't work as expected.
Hi to everyone!
I have a custom board (based on nRF52832) with two LEDS and other GPIO ports. In some point of the code I have to activate one device by setting one port to 1. This is designed like that for power saving. But I realized this device never turns on.
Unless there is other way, I use the function nrf_gpio_cfg_output to configure the port and the functions nrf_gpio_pin_set and nrf_gpio_pin_clear to turn the device on and off, respectively.
After some tests I detected that even the LEDs (and the other GPIO ports) are not working correctly (but in nRF52832DK they worked). If I use nrf_gpio_cfg_output with one LED, then this LED lights up until I use again nrf_gpio_cfg_output with other port (for example with the other LED).
After configuring (I hope) the LEDs as output, when I use nrf_gpio_pin_clear the LEDs lights up and when I use nrf_gpio_pin_set the LEDs turn off. So the result I get is exactly the opposite I expected.
Any Ideas why this is happening?
Could be a problem with crystals or something like that?
Thanks in advance!
