enable debug in thingy52
Hello guys.
I'm new with nodic nRF52 SDK and I tried to enable debug by setting 1 on "NRF_LOG_ENABLED" in sdk_config.h, but nothing happens in com port criated by Jtag (pca10040).
Where is my error? What is the correctly procedure?
  • Line 273 of the makefile had the following line:
    #CFLAGS += NRF_LOG_ENABLED=1 # Use if RTT output is desired.
    I uncommented it and added the -D in front.  Maybe I'm trying to compile the wrong version of the Thingy FW.
    I compiled the debug version of the Thingy FW.
    Are there two different FW versions in the Nordic-Thingy52-FW-master directory, one for debugging and the other for release?  Or did you mean that the firmware was made into a debug version by applying the changes to the sdk_config.h file? Right now I'm compiling from Nordic-Thingy52-FW-master\project\pca20020_s132\armgcc.  There's another directory (Nordic-Thingy52-FW-master\project\bootloader_secure\pca20020_debug) that obviously has something to do with debugging, but there's no makefile and is too large to build in my version of Keil.
    Thanks again!
  • Never mind! It's working now!  I was expecting some debug information on Thingy startup, but I had to go into one of the Thingy services in the smartphone app so that sensor data was being collected.
    Thanks for your help!
  • Great to hear that you figured it out! I am not sure how exactly it works when you use gcc & makefiles, but in Keil & Segger Embedded Studio, you can often choose between a Release Build that could be more optimized for size or a debug build that is easier to debug with. See this link for a good explanation of the difference between the two.
    I do not think you would have needed to change the line:
    to include a -D in front of it.
    I believe the code optimization could be changed by taking a look at line 268 in the makefile:
    CFLAGS += -Wall -Werror -O3 -g3
    It seems that -g3 includes debug symbols in the .out file & you can change -03 to -O0 to decrease optimization, I believe (see link).
