(Mesh)device restart,how to communicate with the previous configuration;
Board: custom board; Mesh SDK: V1.0.0; Softdevice: S132; IDE: SEGGER Embedded; BLE: nrf52832
When I test the steps specified by “Interactive PyACI”, I can Provisioning the client and server, and client can send message to server. but when i restart the board, how to communicate with the previous configuration?
  • today, this problem solved by me .
    Adding this command in flash_load fountion.
        if(type == DSM_ENTRY_TYPE_ADDR_NONVIRTUAL)
            m_addresses[index].subscription_count++;
    static void flash_load(dsm_entry_type_t type, uint32_t index, const dsm_flash_entry_t * p_entry, uint16_t entry_len)
        NRF_MESH_ASSERT(type < DSM_ENTRY_TYPES);
        const flash_group_t * p_group = &m_flash_groups[type];
        p_group->to_dsm_entry(index, p_entry, entry_len);
        bitfield_set(p_group->p_allocated_bitfield, index);
        //add by zhou ,to update the subscription address number , avoid adding subscription address after reboot.
    to update the subscription number after reboot.
    is this a bug?
  • Hi Beike,
    Adding subscription_count increase there might not be best idea. Usually what we do is when we restore model (start by calling nrf_mesh_node_config() from main)  , restore_addresses_for_model() in access.c will be called and the subscription_count will be updated by dsm_address_subscription_add_handle() function.
    The serial example currently demonstrates a simple serialization application, meaning all the configuration data and provisioning should be stored on the peer MCU (or PC). And be restored every time the chip reset.
    If you are creating a standalone node, I would suggest to have a look at the light switch example. In that example the flash is handled properly.
