Problem with nrf52832 xxab.
  • The RAM and ROM in Linker were changed to 256k ROM and 32 kRAM.(in the Linker code which I sent - it's changed)
    I  tested with #define NRF_SDH_CLOCK_LF_SRC 0 too, the same(, but I see in asm code, it stucked in handler:
    SVC_Handler
    For example for xxaa was Linker file:
    /*###ICF### Section handled by ICF editor, don't touch! ****/
    /*-Editor annotation file-*/
    /* IcfEditorFile="$TOOLKIT_DIR$\config\ide\IcfEditor\cortex_v1_0.xml" */
    /*-Specials-*/
    define symbol __ICFEDIT_intvec_start__ = 0x23000;
    /*-Memory Regions-*/
    define symbol __ICFEDIT_region_ROM_start__ = 0x23000;
    define symbol __ICFEDIT_region_ROM_end__ = 0x7ffff;
    define symbol __ICFEDIT_region_RAM_start__ = 0x20001720;
    define symbol __ICFEDIT_region_RAM_end__ = 0x2000ffff;
    export symbol __ICFEDIT_region_RAM_start__;
    export symbol __ICFEDIT_region_RAM_end__;
    /*-Sizes-*/
    define symbol __ICFEDIT_size_cstack__ = 0x800;
    define symbol __ICFEDIT_size_heap__ = 0x200;
    /**** End of ICF editor section. ###ICF###*/
    define memory mem with size = 4G;
    define region ROM_region = mem:[from __ICFEDIT_region_ROM_start__ to __ICFEDIT_region_ROM_end__];
    define region RAM_region = mem:[from __ICFEDIT_region_RAM_start__ to __ICFEDIT_region_RAM_end__];
    define block CSTACK with alignment = 8, size = __ICFEDIT_size_cstack__ { };
    define block HEAP with alignment = 8, size = __ICFEDIT_size_heap__ { };
    initialize by copy { readwrite };
    do not initialize { section .noinit };
    keep { section .intvec };
    place at address mem:__ICFEDIT_intvec_start__ { readonly section .intvec };
    place in ROM_region { readonly };
    place in RAM_region { readwrite,
    block CSTACK,
    block HEAP };
    But when I change the addresses from:
     define symbol __ICFEDIT_region_ROM_end__ = 0x7ffff;->define symbol __ICFEDIT_region_ROM_end__ = 0x3ffff;
    and
    define symbol __ICFEDIT_region_RAM_end__ = 0x2000ffff;->define symbol __ICFEDIT_region_RAM_end__ = 0x20007fff;
    It doesn't start.
  • In your first linker file, it doesn't seem reasonable that the ROM would start @ 0x00000, What is currently your start address and length for RAM and ROM ? Are you using a Soft Device ? What error is the linker giving you ?
  • If you are using a softdevice, the softdevice will be located in the start of flash (ROM), as described in the SoftDevice memory usage specifications. Which SDK and softdevice version are you using?
