What are the limitations when using the S132 central with 20 peripherals connected?
Are there any limitations when the central is connected to 20 peripherals at the same time?  Is there a minimum connection interval (ie, can I set them all to 7.5ms?).
  • First, thank you very much for reporting these issues!
    The SoftDevice has been thoroughly tested for 20 central links, but it seems the SDK has not. I have reported the macro issue, and will try to reproduce the other issues as well, and see if I find a solution.
    Do you by any chance have a sniffer log from a failing session, or is this something you can provide?
