JLink serial (ttyACM0 over usb) drops out, usb device re-enumerates but ttyACM isn't found
I'm using three nrf52840-dk's, from an ubuntu 16.04 x64 host.
  • JLink v6.30b
  • nrfjprog v9.7.2
I can program and interact with two boards fine, with zero of the failures below.  However, the third board is having problems.  This may be the first time I've tried to use the board, and it's always possible there is a HW issue.  I'm hoping to understand what, if any, steps there may be to bring the board back (eg, is there FW on the Jlink or nrf52 side that could possibly be in a bad state that I could fix without scrapping the board).  I've tried different cables; also as mentioned my two other boards work fine.
The problems is that any attempt to write to the ttyACM cause the part to disconnect.
On the board I'm seeing issues:
  1. plug in via USB.
    1. Enumerates fine as both Mass-storage (seems to work fine) and Abstract control module serial (/dev/ttyACM0).
  2. Run, for example:
    1. `nrfjprog -f nrf52 -e --log`
  3. The next message on both `dmesg` and `/var/log/syslog` is:
    1. "Usb disconnect"
  4. This is followed by the device re-enumerating ... BUT the ttyACM and filesystem do not come back
  5. I can unplug and re-plug the device, and my pc enumerates both the ttyACM and the mass-storage
nrfjprog log:
nrfjprog verion 9.7.2
FUNCTION: open_dll.
FUNCTION: open_dll.
FUNCTION: enum_emu_snr.
FUNCTION: connect_to_emu_with_snr.
FUNCTION: connect_to_emu_without_snr.
Updating firmware: J-Link OB-SAM3U128-V2-NordicSemi compiled Jan 12 2018 16:05:20
Replacing firmware: J-Link OB-SAM3U128-V2-NordicSemi compiled Jul 24 2017 17:30:12
JLinkARM.dll OpenEx returned error 'Communication timed out - Can not execute firmware update'.
FUNCTION: close_dll.
developer@7a2d4d5d225c:~/nRF5_tools/nrf5_sdk/examples/ble_peripheral/ble_app_hts/pca10056/s140/armgcc$ exit
exit
As above, immediately after executing the nrfjprog, the device disconnects, then re-enumerates (but, apparently in a problematic state as ttyACM0 doesn't return)
kernel: [1116808.385970] usb 1-5.1: USB disconnect, device number 64
udisksd[2229]: Cleaning up mount point /media/mike/JLINK1 (device 8:16 no longer exist)
kernel: [1116808.422544] FAT-fs (sdb): unable to read boot sector to mark fs as dirty
kernel: [1116808.654667] usb 1-5.1: new high-speed USB device number 65 using xhci_hcd
mtp-probe: checking bus 1, device 65: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.1"
mtp-probe: bus: 1, device: 65 was not an MTP device
kernel: [1116808.755452] usb 1-5.1: New USB device found, idVendor=1366, idProduct=0101
kernel: [1116808.755454] usb 1-5.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
kernel: [1116808.755455] usb 1-5.1: Product: J-Link
kernel: [1116808.755455] usb 1-5.1: Manufacturer: SEGGER
kernel: [1116808.755456] usb 1-5.1: SerialNumber: 000683350409
wpa_supplicant[1618]: wlp2s0: CTRL-EVENT-SCAN-FAILED ret=-100
What can i do to triage / possibly fix this?
