MacOS Bluetooth connnection problem
Hi All,
My configuration:
  • nrf52832 microcontroller
  • Softdevice S132 V4.0.2
  • Nordic SDK 13.0
I have problem with MacOS computer.
If I try to connect via BLE using a MacOS system, nrf52832 aborts connection and reboot automatically.
Instead, there are no problem if I connected to nrf52 with a windows system, android phone or iOS phone.
I'm using these values for GAP Configuration:
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(15, UNIT_1_25_MS)
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS)
#define SLAVE_LATENCY 0
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(6000, UNIT_10_MS)
I'm using these values for Connection parameters:
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3
uint32_t err_code;
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
Error occurs here:
case BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST:
err_code = sd_ble_gatts_exchange_mtu_reply(p_ble_evt->evt.gatts_evt.conn_handle,  BLE_GATT_ATT_MTU_DEFAULT);
APP_ERROR_CHECK(err_code); //NB: return error code = 8
It returns error code n. 8.
Could you help me please?
Thanks
