I've recently enabled the watchdog in our project which included buttonless DFU. Project is based on FreeRTOS, SDK14.0, S132 v5.0.0 on custom board nRF52.
Since the bootloader is currently in a locked state and can't be modified, I set the watchdog timeout in the application to 5 minutes.
What I'm seeing right now is that upon DFU failure, the bootloader hangs just before launching the application on:
nrf_drv_clock_uninit();
Specifically on:
while (nrf_clock_lf_is_running())
Which tells me that it can't turn off the LF clock since the watchdog is using that. Am I correct?
The device recovers after a watchdog reset.
Without the watchdog code, the bootloader works well.
My application settings are the following:
#define CLOCK_ENABLED 1
#define CLOCK_CONFIG_LF_SRC 1
#define CLOCK_CONFIG_IRQ_PRIORITY 7
main function flow:
ret_code_t err_code = nrf_drv_clock_init();
//Configure WDT.
nrf_drv_wdt_config_t config = NRF_DRV_WDT_DEAFULT_CONFIG;
err_code = nrf_drv_wdt_init(&config, wdt_event_handler);
err_code = nrf_drv_wdt_channel_alloc(&m_channel_id);
nrf_drv_wdt_enable();
//init GPIO
//init SD & Freertos
Like in the WDT example.
Bootloader's settings are
and nothing else has changed regarding the clocks and watchdog.
What could be the reason for the failure? Can I integrate the watchdog at this stage?
Thanks.
